best choice for a air filter
im not sure what kind of air filter to get for my engine im getting a sportwerks .26 engine here pretty soon and a really dont want to use my stock air filter from my buggy. i want it to fit the elbows from the sportwerks engine im getting the engine off of amainhobbies.com there is three of them to get a different tune of your engine.
1 Post
RE: best choice for a air filter
The stock MGT air filter is pretty good - it's a beefy 2-stage foam filter - http://www.rcxshop.com/product_info....oducts_id=1317
Then of course there are the "motor saver" air filters, which most people regard as the best air filters around. Whatever you do stay away from K&N!
1 Post
K&N filters were never designed for small 2-stroke rc cars - they don't filter the smallest particles as well as oiled foam filters. They're often marketed as rc car specific air filters (on ebay and such) but they're just rebadged breather filters for 1/1 cars. You can usually tell by the hose clamp fixing...
They may do ok in most conditions, but if you run anywhere dusty i reccomend a different filter
i do run it in all kinds of stuff from sand to powder dirt to gravel...i just stuck the foam piece inside of the k&n because i noticed it was basicly just some fine wire mesh...so i cut my orginal foam fliter and stuck it inside....just take it out and clean and re oil
ORIGINAL: ry5no2
what are motor saver filters
my uncles is like one of those in a box, well he has one, he uses a metal one
Ryan
Ryan
I run the ofna air filter foams with the motorsaver outer foams. I have that same engine also, you will enjoy it especially with the 9mm carb insert..
