Over revving an engine
How do you know if your over revving an engine? Play it by ear? Obviously you don't want to rev the piss out of a nitro engine while there is no load, but when I'm going WOT with my buggy, I want to make sure I'm not going overboard. How can I be cautious to this? Thanks.
UT
What does "WOT" mean...? And why whould you drive it with out a load? and yes, i think over reving does hurt your nitro. it causes pre-mature wear on the parts, so then they will wear down faster and you end up haveing to buy more parts sooner.
Sorry, WOT is Wide Open Throttle (I'm a 1:1 car gearhead, sorry for the jargon) I won't rev it with no load, but I'm just curious. I just don't want any grenades.
They say you should not run WOT for extended periods of time in most manuals i have looked through. I take that has meaning do not run top speed constantly.
FL
you should be hearing just a crisp clean rev just play it by ear if its not overheating it shouldnt be overreving
ORIGINAL: nitro fanatic
You can rev the engine when there is no load... But don't do this for long periods of time.
MI
ahh a fellow gearhead.
if you ever had your cruise control diaphram stick wide open you know what ANY engine sounds like over revved. i have the same issue with a buggy, the trans was not shifting into second. i watch for power, and when i see it drop off, so does the throttle. if you stick it on some dirt it can give you a better feel. also IMO the engine gets a weak, kind of quiet exh note.
MN
ORIGINAL: SManMTB
When racing boats I pretty much ran WOT for 30 mins straight only letting off the gas one on the straight.
So really, if you are going to do speed runs on the street, simply let off once you hit top speed.
