bearing questions
Old 10-09-2007, 08:43 PM
Nitro212
Default bearing questions
Hi, well i have to change the bearings on my OS engine "O.S. Crankshaft Ball Bearing Rear 18CV-R" should i get the one from OS? or is there a better brand more durable ect?
if tehre is.. can some point me to it?
thank you
Old 10-10-2007, 07:25 AM
The Winner
Default RE: bearing questions
you can replace with boca bearings which are the best bearings but you can find some skf bearings for high rpm use from skf stores!
Old 10-10-2007, 03:30 PM
Nitro212
thanks! i foudn some nice boca bearings. I will give it a shot, they are more cheaper than the default OS. I will give it a try see if they work better for me, if not, i'll try the other ones u mentioned but i had a hard time finding one.
Old 10-11-2007, 06:26 AM
The Winner
skf bearings you find it at automotive shops but notice to buy the same dimensions and for high rpm use!and the outside bearing get it sealed!
Old 10-11-2007, 02:07 PM
Nitro212
how do you seal them? the boca bearings come sealed?
Old 10-11-2007, 02:30 PM
Pillbots
Pillbots's Avatar
Depends on what one you buy. He was just saying that you have to get a sealed bearing for the outer engine one and the inner bearing should be without rubber or metal shields.
Old 10-12-2007, 07:19 AM
The Winner
exactly!but you can seal a metal shield bearing with rtv!~ i have seal in the past all the bearings from my mad force!
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
