Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Reload this Page >
Rx21p5 Engine Tuning/starting Problem
Old 04-16-2003, 12:36 PM
Whoison2nd
Default Rx21p5 Engine Tuning/starting Problem
Ok I have had this engine running and its on its 5th tank.. I can't get it started back for some reason.. I have double checked everything and still nothing... Any suggestions on Carb settings and what type of glow plug to use.. i'm using 30% Trinity race blend..
clay
Old 04-16-2003, 03:39 PM
nitroman88
have you taken out the glow plug and seen if it is bad? this is a common occurance when breaking in engines. Also make sure your glow igniter is good.if you had it running for 5 tanks I doubt its a tunning problem. Also if you keep on turning it over the engine will get flooded making starting almost impossible.
Old 04-17-2003, 12:11 PM
Whoison2nd
Yeah Glow plug is good, ignitor is working I can't figure it out.. If any one has this engine could you please tell me your carb settings and type of plug and if any shims that you added??
clay
Old 04-17-2003, 01:20 PM
KyleSch
Go through the deflooding procedure (even if it doesn't seem flooded) and set the all needles to their stock position.
