What Do You Own?
Old 04-02-2008, 11:04 AM
Longhair
Default What Do You Own?
List what you currently own
HPI Savage 4.6 SS --> Converting to Electric
Tamiya F-150 4x4 Racing Truck (#58161)
Tamiya TLT-1 Max Climber (#47202)
Tamiya TXT-1 (#58280)
Brum (discontinued from Radio Shack)
Currently being shipped:
Tamiya Knight Hauler (#56314)
Tamiya Semi-Trailer for Tractor Truck (#56302)
Old 04-02-2008, 11:09 AM
JB COMP
JB COMP's Avatar
Default RE: What Do You Own?
Jammin CRT
LX Comp
T-maxx
Mach 427
STS 21B
STS 30Rev2
TRX 2.5R (modded)
DX3.0
Just a few, could have more.
Old 04-02-2008, 11:24 AM
adam-69
adam-69's Avatar
cen matrix
hyper st
losi 8ight
schumacher cougar
go .21 7P
go .28 3P
go.28 6p
mach.28 6p
nx-26
MX-3
3PM fasst
Old 04-02-2008, 11:28 AM
Anomie
Anomie's Avatar
1 Broken Clodzilla
1 'I don't know anymore'
1 TA-01/02 shortened-wheebase Blazer unfinished
Sold off all the radio/battery/charging/electronic equipment to finance the 'I don't know'.
I think I have a few Deans and some motor heatsinks somewhere.
Old 04-02-2008, 11:32 AM
jrmayer87
I own losi lst2,ofna ultra lx comp,t3,evader st electric,schumacher rascal mini lst,evader bx electric
Old 04-02-2008, 11:44 AM
Foxy
Foxy's Avatar
Well, this is what 'My Models' is for in your profile, and it doesn't really belong in off topic, as it's RC related. Never mind, though, I suppose it gives us an opportunity to go into more detail.
I currently have an Xray NT1 1/10th nitro pro touring car, with the Xray multi-diff, otherwise it's stock (can't improve on near perfection )
And two projects which are in my sig there, and are underway right now, both in mid transformation...
The first is my HPI Baja 5b, the Stealth Bajomber, as I say, work is in progress, so don't ask for pics, yet. It started life as an RTR, but now has spektrum, and the following upgrades waiting to be bolted on...
DDM air filter outerwear black
DDM pullstart outerwear black
Black Baja 5b Windows
Black Mielke side pipe
RR 18/55 steel pinion and spur
PPH 27cc 4.3hp headkit (black circular type head)
HPI alloy diff case
Carbon rear upper deck
Carbon full front shock tower
Carbon roof plate
Carbon front arm braces
Carbon front upper chassis brace
Carbon gear cover plate
Carbon rear upper tank brace
Carbon engine mounts
Black painted body
Black Darksoul OMF billet aluminium beadlocks
Black Darksoul axle extenders
Black DDM Biohazard billet aluminium gas cap
Black billet aluminium choke lever
Black shock socks
Black billet aluminium HD turtle shock tower braces, front and rear
Proline Badlands rear tires
VVC SS lower shock cap set (to accept the 6mm shock shafts in stage 2)
That's stage 1. Should be ready for photos and a vid in about a week, maybe 2, as an order has been inexplicably delayed from Holland. After April I'll see what to get next out of the list of remaining items I plan for the car...
Allanach alloy clutch bell with steel insert
Pico or TGN failsafe (haven't decided yet)
Lauterbacher or Elcon clutch (haven't decided yet)
DS Meaty chromoly steel dogbones and Turtle Racing reinforced drive and axle cup set
ADA enclosed clutch bell carrier/engine mount
GH alloy spur gear holder
A secret I'm not prepared to share at them moment
Lightened flywheel
Billet alloy side engine mount (rear left, behind pullstart)
TeamFastEddy stainless steel quick adjust turnbuckles
AMS Chassis protector black
Phatdad steel nutted hingepins (no more E-clips!!)
Carbon rear arm braces
Phatdad 6mm steel SS replacement shock shaft Kit
Carbon rear chassis
Black HPI main chassis
Black billet aluminium pullstart handle
Rhino full carbon fibre body (yes, that's right, a $300 REAL carbon fiber moulded body)
Billet aluminium transmission case (custom anodised black, hopefully)
Ultraviolet (blacklight) underbody lighting.
That's about it. A few more small items may get added to that list between now and completion. This baja will be awesome.
I also have a currently 'mostly' stock FG Monster Hummer, which is in the middle of a transformation into Herbie, the legendary wheelie pulling, mind of it's own VW bug. I have everything I need to start that project now, EXCEPT the pipe, which is painfully in the same missing order from holland, that I mentioned above. Now, it's just a matter of getting down to wrenching and waiting for the pipe... Stuff that will be on that car when complete is the following...Stage 1 items are already here and waiting to be fitted, stage 2 will probably be done over summer, while I'm on the beach with the Baja.
Stage 1:
RN Fat Tuning Monster Power S pipe
FG Wheely Bar
Alloy rear upper arms
Alloy gear carrier
Alloy brakes and fibre disc upgrade
Monster Beetle Pro body
MB Pro wing
Alloy engine mounts
Front cable disc brakes
Shock socks
Steel spur and carrier
Lexan gear protector/cover
Pullstart cover
Stage 2:
Alloy differential case set
Alloy front wheel hubs
Alloy rear wheel hubs
Special wheelnuts
Alloy diff carrier/rear bulkheads
Alloy front bulkhead set
Alloy front shock tower
Alloy rear shock tower
Ball drive transmission set
Wow, that's a long post. So, both cars should be completely finished by Christmas, but don't think they are going to sit on the shelf til then! Oh no, plans were carefully made so that the cars are never out of action for more time than it takes to rebuild them. So regular progress shots and vids will be coming in another thread I will make in a few days, dedicated to these two projects. That will be posted in the large scale forum.
Large scale gas cars. It's a sickness I tell ya. Someone's bound to ask the dollar amount on all that, and including the NT1, that's many thousands of $$ right there. Baja is already $3k worth, $4.5-5k when finished I'd guess. FG is currently pushing about $2k as well, and about $3k when finished. NT1 as it is with the engine, electronics and setup kit, is probably about $1.5k. That's $5.5k now, about $10k+ altogether when done. Money well spent.
Old 04-02-2008, 11:47 AM
compression
tt-01 (collecting dust)
ta-05 ifs (NIB and collecting dust)
globeliner (NIB and collecting dust)
txt-1 (somewhere in my closet)
tlt-1 max climber (gathering dust on my shelf)
all tamiya btw!
Old 04-02-2008, 11:56 AM
DarkFire989
DarkFire989's Avatar
My sig, too lazy to list.
Old 04-02-2008, 12:02 PM
qaiz
qaiz's Avatar
1/8 Scale
Hyper ST - Picco .28 - Nomadio React
Losi 8ight T ( Dad's ) - Nova 367 - Spektrum DX3R
X1X CRT Pro - SH .28 / OS V Spec - Nomadio React
Kyosho ST RR NIB Collecting dust ( Will be sold Tomorrow )
Nitrage Collecting Dust - OS .30VG - JR XS3
Hyper ST Pro NIB Collecting Dust - Ninja .28 - Futaba 4PK ( Still dont have the radio )
Deciding on my next truck soon - Probably the Xray XT8
1/5 Scale
Baja SS ( Mine sold, Dad's one is with me ) - Zen 26 - Spektrum DX3R
FG Monster Jeep ( In the cargo hold of some ship ) - 27 Modded and Ported - Nomadio React
Saving up for a MT Beetle Pro
And like 15 X-Mods, 14 of which dont run.
And like probably $1.5K in tools, which again, in the cargo hold of some ship [&o]
Love them all
Old 04-02-2008, 12:23 PM
Anomie
Anomie's Avatar
ORIGINAL: Foxy
HPI alloy diff case
Carbon roof plate
Black painted body
Black shock socks
Lightened flywheel
Carbon rear chassis
Stage 1:
FG Wheely Bar
Alloy gear carrier
MB Pro wing
Alloy engine mounts
Shock socks
Pullstart cover
Stage 2:
Special wheelnuts
Showoff
Just wait until I finish my hybrid turbine nitro electric steam powered computer controlled Nylint! I'll give you what-for!
Old 04-02-2008, 12:33 PM
adam-69
adam-69's Avatar
ORIGINAL: Reiko
Showoff
he may wait a while
Old 04-02-2008, 12:59 PM
st_dragn_wagen
st_dragn_wagen's Avatar
XXXT
tamiya mini cooper (M03 chassis)
HPI nitro RS4 2
bolink eliminator
kyosho stadium baja
unidentified kyosho nitro (i think it was a 2 wheel drive stadium truck)
and i used to have a T3
and "radio shack" stuff
zip zap
nikko 4x4 monster camaro (iv had sense i was like 4 or 5)
tyco lamborghini countach
i don't remember the name of'm 56 ford trucks picked'm up at radio shack a while back
some crappy 2 wheel drive no suspension buggy i picked up for 20 bucks to run in the house
used to have a tyco fast traxx truck
Old 04-02-2008, 02:17 PM
Foxy
Foxy's Avatar
I had words since that post with the guy in holland about the missing order. Apparently he hasn't sent it out yet. Over a month. He had previously agreed to send everything except the pipe which he had on back order. That was the 19th. Now he emails me and asks me if I want him to ship the rest (again). I was PISSED. I cancelled the pipe and told him to send the rest express immediately. Fingers crossed he can manage it.
So now I need a different pipe, or another source for the RN. [&o]
Reiko, you have until Christmas to provide me with some worthy competition.
Old 04-02-2008, 05:33 PM
justinep
justinep's Avatar
ORIGINAL: Foxy
HPI alloy diff case
Carbon roof plate
Black painted body
Black shock socks
Lightened flywheel
Carbon rear chassis
Stage 1:
FG Wheely Bar
Alloy gear carrier
MB Pro wing
Alloy engine mounts
Shock socks
Pullstart cover
Stage 2:
Special wheelnuts
anything else? hahahaha Pretty awesome my man!
Here's my list of car greatness:
Bandit VXL w/ RPM hop-ups, 34/76 gearing, road hawgs, 5000mah 3s lipo (maxamps)
Associated 10L3 Touring w/ 6 pole BL motor, MGM esc, 4s/ 5s 5000mah lipo(s), Drag conversion, 69 camaro body, Ven Speed Meter (my highspeed car) 24/76 gearing
Associated TC-3 w/ 9200kv duo BL, Mamba Max, 7c 4500 Elite, 'Cuda Body, Vintage wheels and tires, new adjustable threaded suspension 18/76 gearing
Rustler (1st gen) w/ 3500kv BL, Mamba Max, 3s 4000mah maxamps lipo 28/76 gearing, chromies, RPM front housing pieces, full bearings
Tamiya TL-01 w/ 12t triple, 8 3000 cells, tekin speedstar, full bearings, speed tuned gears, oil filled shocks, escalade body
Bolink Econorail Dragster w/ 3.5t BL, Mamba Max, 3s 4000 lipo
Kyosho Nitro Thunderbird (from '92) w/ new OS cv .12, 3rd stage head w/ fabbed shim and exhaust, BPM boost tank, k&n air filter, new fabricated brake system.. completly re-done and shelved after I tested and tuned but, plan on bringing her back out this summer
Old 04-02-2008, 05:44 PM
drevil
Cars/Trucks:
FG Marder 1/6 scale buggy
Axial AX10 Scorpion
Team Associated TC4 Team
Team Associated RC12L3
Tamiya TA04S (for sale)
Helis:
Heli-Max Axe EZ
Piccolo Fun micro heli (also for sale)
Previously owned:
Tamiya Blackfoot (8 wheel pulling truck)
Tamiya Bullhead
Tamiya Clodbuster (Clodzilla IV)
Traxxas Hawk II
Tamiya Sauber F1
Tamiya Bruiser
Compagnucci 1/8 gas powered onroad car (piece of junk)
Team Associated RC10GT
HPI RS4
Kyosho Blizzard
Kyosho Hyperfly heli (another piece of junk)
Old 04-02-2008, 06:20 PM
Frozen72
Frozen72's Avatar
Evader EXT
Team Orion SV2 15T
Masher 2K's
CVD's
Tazer 12T
Futaba sx3003
ST Tranny conversion (ball diff)
Vendetta ST
Ball Diffs (Front and Rear)
Timed VR3
Mini-LST shocks
Doubled up Rear Shock Tower
Street Tires
Mini Quake Tires
HS-225MG
Elite 1500mah
Mini-T
HS-55
Orion Baja
Elite 1500mah
Pro-Line Crowd-Pleaser body
Needs:
Dirt Hawgs
Chassis
Bulkhead
Bulkhead Brace
Old 04-02-2008, 06:40 PM
Deftones123
currently own
Team losi Mini-t-custom(mamba) etc
Duratrax Warhead Evo
used to own
a redcat racing shockwave buggy but sold it
Old 04-02-2008, 07:22 PM
The Mad Modder
The Mad Modder's Avatar
Tamiya M03 Mini Cooper(skidplates)
Tamiya Double Blaze(um...cool paint job?)
A-tech Leo-X (axle mounted servo, novak spy, venom fireball)
Losi Mini Baja(dynamite motor plate, RPM bumper, Lunsford lexan gear cover, going to go brushless and add bb equipped bell cranks)
1/8 Rammunition
and...
...the Double Whammy!
The Double Whammy is a Traxxas Sledghammer. I added second gearbox on the rear, making it a 4X6.
It has: trinity p2k(x2), pro-line dirt hawgs on the rear and Trac-ta-gators on the front.
(The tractagators help steering tremendously.)
Old 04-02-2008, 07:26 PM
The Mad Modder
Foxy, You've got to show us a pic of your 5b. You must have about $1,000,000 in it.
Old 04-02-2008, 07:56 PM
daveholm
The double whammy is pretty cool!
At the moment I only have two trucks:
E-LST2 (custome build by 3 Phase Racing - Owned by RURC)
Nue 1515/1.5d/H
MM ESC on 4S LIPO
At the moment it is in peices being hopped up with:
RPM arms all around
Lundsfurd titanium hing pins and turnbuckles
Raven RC shock springs
Delrin Spur gears 69t & 62T
Hex heads screw kit
JR Z650M steering servos
Associated Servo savers
Dynamite engine brace
23mm Hexs
Big Joes
E-Revo Gorrila Max G3R conversion
7XL Fiegao
MM ESC on 4S LIPO
It will be upgraded when I get done with the LST2 with:
RPM Arms all around
RPM Axle carriers
Once both trucks are upgraded I will post picks in my profile.
Next purchase is going to be a large scale just not sure wich one.
I really like the MCD Baja1000 but I have to agree with Foxy about MCD being over priced.
Otherwise I have been paying very close attention to the reports about the Smartech Titan and I still really like the FG MB Pro but prefer 4x4.
Old 04-02-2008, 09:49 PM
calvino
calvino's Avatar
RC18T
metal diff gears (F&R)
Mip Super Diff (rear now)
Steel turnbuckles (no toe, they bent/broke)
Pro-line Dirt Hawgz
Assocated Dish Rims
RPM shock towers (blue)
RPM A-Arms (need to install, to lazy at moment)
RPM wide bumper
SP19T motor
HS-65 MG servo (need to get, oldie broke)
Stock 18MT rims for drifin
Assocated Goldpan RC10
duno upgrades
Radio Shack ___ (few pics in gallery)
waterproofed
Slow Stick Plane
brushless outrunner
2 HS-55 sx
Berg 4l reciever
3s 2250 mah lipo (beast)
that is all I got[>:]
Old 04-02-2008, 11:03 PM
fullfun
well lets see here we go now what i own is 2 electric rustlers , two electric stampedes , two mini-t's , a t-maxx , an aftershock , a cen funfactor bg , a smartech magic wheel , and an old traxxas rad 2 , and oh yeah three control line planes as well . and of course a bunch of parts good and bad and tons of old worn tires which make great turn markers in the yard and parkin lots lol
Old 04-02-2008, 11:17 PM
ssj2
ssj2's Avatar
I currently own:
Mugen MBX5T Prospec w/Futaba 3PK and Spektrum Module
Tamiya Thunderdragon
All upgrades and such can be seen in My Models, all of that stuff is up to date as far as mods and pics.
Old 04-02-2008, 11:31 PM
bte214
bte214's Avatar
Rc10's -T4, B4 in the mail, TC4, GT
E-Maxx
Micro Street Force
Maximum BX
Kyosho Viper R
Dynaflite Butterfly (in box)
Old 04-03-2008, 12:59 AM
SpaceSuit Monkey
My current cars:
Associated RC10 Gold Tub
with stock equipment
Associated 18B
with Kirkland AA's in transmitter (WOOT)
Recently departing with:
Vintage Tamiya Blackfoot
Vintage Tamiya Falcon
Vintage Tamiya Grasshopper
2 Vintage MINIATURE Kyosho Ultimas
