twin carbs
Old 04-05-2008, 01:47 PM
rcpowerhorse
rcpowerhorse's Avatar
Default twin carbs
i was just wondering can you mount two carbs on one nitro and if you can would you get a performance boost??
Old 04-05-2008, 02:30 PM
Codeblack
Codeblack's Avatar
Default RE: twin carbs
no.... no no no no no...
no
Old 04-05-2008, 02:48 PM
The_Collector
The_Collector's Avatar
Only a multi-cylinder engine can take advantage of a multi-carb. setup.
Old 04-05-2008, 03:17 PM
ProRCRacer88
of coarse you can, but it will add weight, take up space, and do not a damn thing but screw things up...
Old 04-05-2008, 03:44 PM
annie_himself
annie_himself's Avatar
You can use CA to put it on the cooling head but I don't thing the air will reach the chamber.
Old 04-05-2008, 05:54 PM
Xtfreak
Xtfreak's Avatar
Come on guys he's just asking a simple question.......................................... ............umm the answer is no....no....no...and no again
Old 04-05-2008, 06:06 PM
The_Shark
The_Shark's Avatar
nope it wont work, but a bigger carb will help, but too much mixture in a engine that isnt tolerated for that will most likely break. plus youd have to bore the intakes to use the bigger carb and shim the engine along with a different temp glow plug.
its just like dual exhaust on these things, they dont do a damn thing but loose scavenging from lack of back pressure.
Old 04-05-2008, 07:40 PM
adam-69
adam-69's Avatar
where did you think of mounting it? the answer is no but i dont know how you meant it to work? [&:]
Old 04-06-2008, 12:23 AM
rcpowerhorse
alright i was just wondering
Old 04-06-2008, 01:17 AM
BUGGIES_R_US
BUGGIES_R_US's Avatar
Maybe a sequential twin carb makes sense
No, single is best.
Old 04-06-2008, 04:43 AM
rcpowerhorse
but wait have any of you tried it??
Old 04-06-2008, 11:11 AM
Codeblack
Codeblack's Avatar
ORIGINAL: rcpowerhorse
no need to.. you would need more displacement to handle a larger amount of air/fuel.
Old 04-06-2008, 11:16 AM
GYNAIKAS
GYNAIKAS's Avatar
No way...no boost. Actually it will never work...
Old 04-06-2008, 11:26 AM
rcpowerhorse
ah right
