Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Reload this Page >
Keep your air filter clean and oiled......some intresting facts.
Old 04-05-2008, 04:46 PM
brettkrupa
Default Keep your air filter clean and oiled......some intresting facts.
I was curious as to how much air is actually be sucked through your air filter and what kind of load it is actually under, as I always thought it to be a little extreme to clean it after everyday. Well now I realise how important it actually is, here are some numbers for you to think about.....
I will be using my Ofna Force .32 engine for all examples:
So lets say that of my .32 sized engine each stroke I am getting about .28 cubic inches of air in it, On average I would guess I am doing about 3/4 throttle ( I run it hard ) so that would be about 28500 RPM's. To calculate how much air it consumes every minute you would go .28(cubic inches of air) and multiply it by 28500 (rpm's) to get an answer of 7980 cubic inches of air. I am Canadian so I am going to have to convert this to litres, sorry. So that's 131 cubic litres a minute times 60 to get litres/hour and you get 78600, I will usually get about 4 hours in of driving a day so that means during the day about 301000 litres of air. That's a little over 2 times of what an adult male breathes in a period of 24 hours! So it consumes air 3 times as fast as us when we are semi relaxed. Now go for a run, do some sprints, come back and try breathing through a dirty air filter, I bet you will pass out from insufficient oxygen. In the lifetime of my engine, enough air will have gone through the air filter to fill several swimming pools! Now go clean your darn filters!
A couple corrections, One of my sources was off, After 4 hours of driving it consumes as much air as 20 people do over the course of an entire day!
That's a few swimming pools of air every 4 hours, a little under 75 Olympic pools in its lifetime (knock on wood)
Old 04-05-2008, 06:01 PM
The_Shark
The_Shark's Avatar
Default RE: Keep your air filter clean and oiled......some intresting facts.
same priciple as a car. those engines SUCK air, especially with a turbo.
i clean mine once a day too, i only use engine or light bearing oil to oil them, i also have a can of K&N that i use, just a spert and its all good. (bet its cheaper than nitro air filter oil.)
Old 04-05-2008, 06:08 PM
s7jstep1
s7jstep1's Avatar
i clean mine every 2-5 runs. i hve the motor saver on my revo so its better than the stock one. when i run, i usually only run for about 3-4 tanks. lately i can even get through a tank before something messes up[:'(]
Old 04-06-2008, 07:29 PM
Nitro212
so whats the bets way to clean it? x_x
Old 04-06-2008, 07:37 PM
sheograth
Moderator
sheograth's Avatar
I'm obsessive about air filter cleaning.
Old 04-06-2008, 07:47 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
i was a newb with my nitro sport se, but i would clean my filter after every use. sometimes, when i ran in sandy areas, id clean the filter after every 2-3 tanks!
Old 04-06-2008, 07:49 PM
Dokioto
Dokioto's Avatar
ORIGINAL: Nitro212
Soap and water
Old 04-06-2008, 07:54 PM
sheograth
Moderator
sheograth's Avatar
Yeah thats what I do. Thoroughly clean it with soap and water, dry it completely, oil, and go.
Old 04-06-2008, 07:58 PM
brettkrupa
I fill up a container with hot water and dish soap, let it soak for a good five mins, then I squeeze the water out and put it back in the water again, repeat until water is coming out clean. Now the tricky part is getting a nice oil job, what I usually do is take a small sandwich size zip-lock bag and put a couple teaspoons of air-filter oil in it then close the bag and move it around so the oil is evenly covering all sides of the bag, then I put the air-filter foam in and slide it around while squeezing until it is evenly covered, you have to rotate it too which is a little tricky.
Old 04-06-2008, 08:02 PM
[]TEX[]
[]TEX[]'s Avatar
I never cleaned mine, ever, ran fine. .28ci of air is really small to consume at one time. The air filters can inlet much more air than that at one time. So, not a big deal really.
Old 04-06-2008, 08:12 PM
brettkrupa
True, .28 ci is a small amount of air, but at some odd 28000 rpms its like a constant suck because the engine has such a short time in between each stroke.
Old 04-06-2008, 08:17 PM
The_Shark
The_Shark's Avatar
you ever feel how much air is pumped out of the pipe? thats alot of air.
ever drive a car with a dirty filter? biiig power drop, can be as great as 15HP and alot of bogging.
Old 04-06-2008, 09:20 PM
Dokioto
Dokioto's Avatar
ORIGINAL: Shupid_one
I hope your not talking about an R/C car
I have yet to see any .28 give out 15HP..
Old 04-06-2008, 10:28 PM
brettkrupa
Correction, I made a mistake, driving my ofna for 4 hours will pull as much air through the air filter as a group of 20 people breathe in a day! Now that is crazy!
Old 04-06-2008, 10:31 PM
brettkrupa
And It consumes enough air to fill 3.5 average pools a day. 75 olympic pools in its lifetime!
Old 04-07-2008, 07:45 PM
brettkrupa
Now thats alot of air.
Old 04-07-2008, 07:52 PM
C_ImpulZ
When you put it that way. I might make more of an effort from now on.
How the hell do you get time to run the car 4 hours a day ????
Old 04-07-2008, 08:17 PM
The_Shark
The_Shark's Avatar
a day off and lots of extra nitro!
now, imagine a real car....[X(]
Old 04-07-2008, 08:31 PM
brettkrupa
Haha, well I am glad my rant atleast got to one person :P
Old 04-08-2008, 01:43 AM
Shark413
I clean mine after every use, cheap insurance for a very expensive part (piston and sleeve). I also use an prefilter over the regular filter and I take spares in case it is really dusty. Have you ever noticed how much crud comes out of your filter when you wash it with warm water and detergent? And that's only the big stuff, the microscopic particles you can't even see. I have a OS .21 V-spec with over 4 gallons thru it and it still has tons of compression. I also have a OS .28XZ in my truggy with about 2 gallons thru it and the insides still look brand new.
Old 04-08-2008, 07:47 AM
The_Shark
The_Shark's Avatar
one time i let the filter go 1/2 gallon and when i cleaned it, it was like black sludge.[:'(] ran so much better after that.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
