wiggly tire
RE: wiggly tire
were the tires
always wiggly?
if not then
yeah, maybe bushings/bearings
or something else worn out
or broken
if yes then maybe
poorly glued tires
or warped rims
always wiggly?
if not then
or broken
if yes then maybe
poorly glued tires
or warped rims
RE: wiggly tire
Look at it close, are the tires wiggling or are the rims wiggling? If the rims are the the tires will also. If the rims are warped then so will the tires. If the rims are true then the tires are glued wrong it would seem.
