Why wont my engine start?
Old 06-06-2003, 04:20 AM
Clown
Default Why wont my engine start?
My Engine wont start because it doesnt have any fuel in the carbarator or in the fuel line. I have already changed the lines so it isn't blocked and when i cover up the exhaust and/ot the carberator hole and pull the pull starter it wont suck any fuel up. What should i do?
By the way it is a GS .15
Old 06-06-2003, 04:34 AM
Dadams2205-RCU
Try putting your finger over the exhaust pipe hole and then pull the pull starter.
Old 06-06-2003, 05:03 AM
Clown
that doesnt work either!
Old 06-06-2003, 05:08 AM
Rex2342
Rex2342's Avatar
Did you check to make sure your fuel tank isn't cracked?Are you leaking fuel from anywhere?Try blowing into the pressure line and see if that gets the fuel to the carb.My rustler doesn't have a primer and covering the stinger doesn't always work and thats how I do it.Just make sure the pressure line is clean before you put it in your mouth.
