Rustler VXL Startup Issue
Old 03-23-2009, 12:06 PM
flyfloatr
Default Rustler VXL Startup Issue
Just got the Rustler VXL and I love it. One problem though, at times when I stop completely it won't move again until I give it a little kick start. Is that normal?
Old 03-23-2009, 12:09 PM
DaveG55
DaveG55's Avatar
Default RE: Rustler VXL Startup Issue
No, not normal at all.
Old 03-23-2009, 12:24 PM
redfisher1974
redfisher1974's Avatar
I would say no...not normal
Old 03-23-2009, 02:05 PM
TIGER76
TIGER76's Avatar
Bit more info m8? does it make any strange noises when it wont pull forward ?? could be a loose slipper , could be a loose pinion gear slipping on the shaft or something loose in the transmisson? give us some more info so we can help ya out..
Old 03-24-2009, 08:34 AM
flyfloatr
it just sits there and you hear a slight beep from the motor but no movement whatsoever. Like it's inbetween phases and can't decide what to do?? Sometimes if I turn back and forth it moves the car enough for it to get going. It sure doesn't seem like anything would be stuck, I would hear some sort of noise from the gearing. There is absolutely no movement or noise other than a slight beep from the motor.
Old 03-26-2009, 10:15 AM
flyfloatr
I pulled the transmision appart, no binding or anything out of order. Also reset the esc and no help. Any other suggestions?
Old 03-26-2009, 06:49 PM
ih8nixon
If it has nothing to do with the transmission, then there may be a bad connection between the esc and the motor. Such as a bad solder joint on the motor.
Old 03-26-2009, 09:24 PM
kistner
My Feedback: (10)
kistner's Avatar
could this be a LVC issue? what batteries are you running?
Old 03-27-2009, 07:45 AM
flyfloatr
I have had the problem with fresh off the charger 4000+mah nimh packs and I have the lvc off. It doesn't seem like it could be a bad connection either because the thing flies, wheelies like mad, stop to turn around and let it stop completely and it will just sit there.
