Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Reload this Page >
Glow plugs, heat ranges, and the correct plug for the right application.
Old 02-03-2018, 11:01 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Originally Posted by blhollo2
can you use a 2 stroke plug in a four stroke engine, as the weather is creating problems for my 4 stroker
Yup. As long as it’s hot enough, surely it will work. I use Enya #3 plugs in my 4-strokes with great results.
Old 03-03-2018, 11:58 AM
mrthrun
Default Thank you
I really appreciate your post. I am seriously considering getting into nitro RC and have been trying to do as much research as possible first. Glow plugs seemed to be a recurring theme but this is the first and only post I have read that actually presents need to know information. You may want to consider doing a youtube presentation of this as well.
Thanks again.
Old 03-03-2018, 02:33 PM
1QwkSport2.5r
Some people just insist on using this plug or that plug for their application without any testing to find which is the best performing and longest lasting. I find the best of both worlds and use that. Many people use hot plugs because they suck at tuning and never try anything else because “it works”. However, colder plugs allow a sharper tune and often this gives much better performance overall at the expense of a little coarser idle quality. Nitro Engines is a balancing act. Often folks choose a heat range based on ambient air temp and this practice isn’t correct either. You tune the plug to the fuel used. Less Nitro needs more heat (hotter plug) whereas more Nitro needs less heat (colder plug).
Old 08-23-2022, 04:48 PM
N1EDM
Does anyone know if the OS #6 plug replaces the old A3??
Bob
Old 08-24-2022, 05:11 PM
suburban_hooligan
suburban_hooligan's Avatar
A3 was a hot plug, #6 is a hot plug. hell it's probably the same plug with a new name.
Old 08-25-2022, 03:29 AM
  #31
N1EDM
That's what I was thinking. I was just curious if I was right or not. Thanks hooligan!!
Bob
Old 08-26-2022, 09:13 AM
  #32
1QwkSport2.5r
Yes, I believe the A3 is the old #6. Same plug, different number. If you like these plugs, I have 3 A3 plugs NIP for sale.
Old 08-26-2022, 12:43 PM
  #33
N1EDM
Thanks for that 1QwkWport2, I've got enough plugs for now. But thanks again for confirming that... I hope you unload those A3's ASAP...
Bob
