32 pitch vs 48?
Old 01-01-2010, 11:30 AM
Default 32 pitch vs 48?
I was wondering if It is ok to use a different pitched pinioin gear. If my mini dt is 48 pitch, can I stick a castle 32 pitch pinion on
I cant get the regular motor gears to stay on the shaft.. They keep loosening.
Has anyone used locktite? Or a specific pin that stays?
With size 1/10 vehic it seems easiers to keep them on since the motor screw that holds it is bigger
thanks</p>
Old 01-01-2010, 11:35 AM
My Feedback: (325)
Default RE: 32 pitch vs 48?
no, they have to be matched in order to get proper gear mesh. Loctite will help the screw stay tight. A relief or step in the shaft will also help, a bigger screw may also help.
Old 01-01-2010, 01:31 PM
MCSRacing's Avatar
32 pitch = 32 teeth per inch
48 pitch = 48 teeth per inch
64 pitch = 64 teeth per inch
Old 01-01-2010, 02:02 PM
OvalRacer99's Avatar
Both the pinion and spur gears need to be the same pitch. You can not mix them, it will damage one or both.
Old 01-01-2010, 05:46 PM
How cn you get s bigger screw for those rc18 pinion gears...rnt you just stuck with the size thats there?
is there a company that makes a bigger screw for rc18 gears? its frustrating having the things pop loose
thanks
</p>
Old 01-01-2010, 07:10 PM
link&gt; [link=http://www.rcdriftclub.com/home/archives/9]Gear Pitch Explained.[/link]
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
