how important is it to match pinion gear pitch?
I know there are 48 and 32 pitch gears. Idont know why that its...Iguess same reason there are macs and pcs?
What is the benefit of one pitch vs another?, and Iam asking for trouble if I mesh a 32 pinion with a 48 spur?
Iam sure the answer is yes, but I cant figure why castle makes only 32 pitch pinion gears
My Feedback: (-1)
AE
RE: how important is it to match pinion gear pitch?
Yes you will run into trouble.Generally 32 pitch is more durable and more suited to run in an open gear car, like a nitro or an electric without running the gear cover.Harder for rocks and whatnot to get stuck.
can you just change the spur gear to match the pinion? Or does it effect the internal workings as well
IS there a way to know what companys use what pitch?
I think losi is 48..but I cant tell by staring at the thing
32 pitch are also used in the classic Tamiya vehicles. I can say for certain that they do not mesh, having swapped motors between a Grasshopper and Dark Impact but forgot to swap pinions. I didn't apply power as I couldn't get a mesh at all, and thus caught my mistake, but I can't imagine it would end well.
And yes, they are more durable. My TB-02 is louder than a nitro from rocks and sand getting in the gearbox, while the vintage cars seem to ignore it. I clean it out regularly but the pinion and spur are ruined.
ORIGINAL: Access
Don't forget, even with pitch (if it's matched), you also have mod, ie. mod 1, mod 0.8 and so on.
ORIGINAL: katzcratch
32 pitch gears were the first thing used in our hobby, and just like 1/8th nitros today that use them it was the standard pitch for gearing on the first on-road RC cars back in the 1970s and early 80s. In the mid 1980s they developed 64 pitch gears, and like today they were primarily used by 1/12th onroad guys to give themselves more gearing options. A few years later in the late 80s marked the release of the first 48pitch gears, and these were the primary choice of offroad races as they were a happy medium, between 32pitch that didn't get fouled with dirt very easily and 64pitch gears that required a lot of upkeep, and still allowed for a greater number of gearing options than the original 32pitch gears.
FL
its not
really about company more so than chassis type and scale
example a 1/10 nitro will almost always use 32p or a varient of it between the endbell and the slipper clutch where as a 1/10th electric will use 48p. a 1/10th or 1/12th electric pan car is the exception to the rule though as most use 64p while others run 48p for whatever reason be it durability or pinion compatibility with other stuff.
also as mech' said a number of vintage cars of varing scales use 32p like my tamiya buggy, rc10l, traxxas fiero, cat, and sledgehammer. you will also see 32 pitch in a number of toy-grade rigs
SD
Just to throw something into this discussion, the term "pitch" on the gears refers to the number of teeth per inch, as in a 48 pitch gear if it was flat would have 48 teeth per inch. With that being said, 32 pitch will never work with 48 pitch.
As far as manufacturers, if it is a 48 pitch it will work with other companies 48 pitch. I use Robinson, Losi and Kimbrough gears and they work together just fine!!
