RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Battery Problems (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/10219506-battery-problems.html)
cooldriver385 12-26-2010 03:40 PM
Battery Problems
I got a Dynamite Twin Peak charger that seems to charge my mini Revo batteries just fine. My aunt got me a new Venom 5000mAh 7 cell NiMH pack for my Stampede. I plugged it into my charger and it said that it had finished after only 15-20 minutes. I plugged it in and the power was unbelievable and then it the battery was extremely low. I looked on the back and it said for a 5000 mAh pack at 4 amps it should take 90 minutes to charge. What is up with my battery/charger? FYI I took the ESC off of LVD mode before I started driving it.
guver 12-26-2010 03:45 PM
RE: Battery Problems
charger shut off too soon? Maybe it did what it was supposed to do.
cooldriver385 12-26-2010 04:05 PM
No it was supposed to charge the battery. I don't know. Does it need like a break-in cycle?
Radiner 12-26-2010 04:15 PM
Don't worry, charge the battery again and use it to break it in, new batteries always does that.
guver 12-26-2010 04:16 PM
Let me re-phrase. The pack wasn't full , we know that. Chargers are designed to turn off when a voltage drop or other parameter is sensed , maybe a voltage drop or other parameter was sensed. I don't think it is the chargers fault and I don't think there's anything wrong with your charger or pack. The pack should really be charged slowly all way to full before use.
cooldriver385 12-26-2010 04:25 PM
Ya I just read up that new NiMH's tend to false peak on their first couple of cycles.
SyCo_VeNoM 12-26-2010 05:13 PM
ORIGINAL: cooldriver385
yup
I've had NiMh batteries take a full charge 1st time, than others that took 10-12 uses to get the full charge starting pretty low, and incrementing slowly.
But he did say its a venom battery... good luck I've had venom's that would only get to around 60-70% capacity no matter what I tried. One of the many reasons I will not use any more of their products even if they were given to me for free.
cooldriver385 12-27-2010 07:27 AM
How many cycles does this thing take until it has stopped false peaking?
cooldriver385 12-27-2010 07:52 AM
Alright this is probably my 4th or 5th cycle and it has only improved a little. Anybody know?
scrofcheck 12-27-2010 09:27 AM
Try charging your battery at a lower amperage. Try maybe 2 amps the first couple of times. The battery will last longer if you charge it at a lower rate. Hope this helps Steve
cooldriver385 12-28-2010 04:32 AM
Well the Dynamite Twin Peak has an "auto selection" on the amperage. So if it's a 4-5 cell receiver pack, the charger charges at 1 amp. If it's a 6-7 cell battery, it automatically charges at 4 amps. I checked the voltage of the battery and it says it has peaked at 9.5 volts. But it still doesn't charge to full capacity. Is there a mAh limit to this charger?
cooldriver385 12-28-2010 04:34 AM
I tried to re-peak it and now it's at 9.8 volts. But I still think it hasn't gotten there yet. Hasn't charged for 90 minutes.
rasper 12-28-2010 09:20 AM
Ive got a twin peak aswell. Did exactly the same on my batteries by not charging them fully, and then i found that the charger cuts out due to "overheating" inside, and it sensed "other perameters" as Guver said. So I took a old hairdrier, stripped it apart and removed the motor with the fan assembly and chuhed the rest. Took some deans plugs and soldered it up and connected it to a seperate battery and just let it run next to or blow into the vent of the charger. Now it work as its suppose to, just by being colled a bit.
The_Shark 12-28-2010 05:23 PM
low and slow, charge it overnight.... twice.
cooldriver385 12-28-2010 06:17 PM
The charger automatically charges at 4 amps. Can't change it. My other two chargers are timed chargers and only charge NiCad batteries. Not NiMH.
