Bad servo, Can i fix it?
Ibought a Hitec HS-645MG for my MGT.
Im not working so i didnt have the money for the 100$ everyone talks about. Anyway a few minutes after running my truck i start losing control. The servos seem to have a mind of there own and now i cant control them at all, The controller/receiver flash red/green and i cant do anything. After i unplug the steering servo everything calms down and works fine. Anything i can do to fix this? Its about 1 mnt old, it worked fine when i first got it. |
RE: Bad servo, Can i fix it?
Have you popped the back plate off to see if there is any moisture in it? There is not much you can do with a malfunctioning servo besides getting it warrantied. Sometimes digital servos cause issues, but yours isn't digital.
there are cheaper than $100. i think traxxas servo are about $30.-40 i just priced a very fast servo, it was $119. i dont need a fast throttle that bad.
ORIGINAL: moe7404 there are cheaper than $100. i think traxxas servo are about $30.-40 i just priced a very fast servo, it was $119. i dont need a fast throttle that bad. It almost sounds like the RX isn't getting enough power to power the servo. Did you try new batteries? I doubt the RX would flash if the servo was just bad (none of mine do) Have you tried hooking the steering servo up to channel 2 and leaving the throttle servo off to test it? |
ORIGINAL: SyCo_VeNoM ORIGINAL: moe7404 there are cheaper than $100. i think traxxas servo are about $30.-40 i just priced a very fast servo, it was $119. i dont need a fast throttle that bad. It almost sounds like the RX isn't getting enough power to power the servo. Did you try new batteries? I doubt the RX would flash if the servo was just bad (none of mine do) Have you tried hooking the steering servo up to channel 2 and leaving the throttle servo off to test it? Ill try removing the reverse servo power first, If ti works i can deal with out that one. If it is a power problem what can i do about it? Im using a 5c Nimh hump pack. Cant reallygo any bigget then thet with out frying anything. |
I had a few free minutes so i tryed it.
Iun-plugged the transmission servo and nothing glitched. BUT when i tryed the steering servo it turned 1/2 way one way-stopped then i had a ton of grinding with alot of humming from the servo. Turned the wheels by hand and still got alot of grinding So it sounds like i have 2 problems to deal with, Lack of power and a bad servo. |
ORIGINAL: bloodpuppy I had a few free minutes so i tryed it. I un-plugged the transmission servo and nothing glitched. BUT when i tryed the steering servo it turned 1/2 way one way-stopped then i had a ton of grinding with alot of humming from the servo. Turned the wheels by hand and still got alot of grinding So it sounds like i have 2 problems to deal with, Lack of power and a bad servo. http://www3.towerhobbies.com/cgi-bin...&I=LXVE87&P=ML Are you using a servo saver? I have used mg645s many times for heavier applications than they were rated for and never had a problem. |
Not working at all anymore. Just a loud hum and the gears arnt working.
Isaid F-it, and went to the LHS and got the 130$ one. Ill turn around and try to fix this one for a back up. |
ORIGINAL: bloodpuppy Not working at all anymore. Just a loud hum and the gears arnt working. I said F-it, and went to the LHS and got the 130$ one. Ill turn around and try to fix this one for a back up. |
hobby partz servos are good and very cheap.
ORIGINAL: SyCo_VeNoM ORIGINAL: bloodpuppy Not working at all anymore. Just a loud hum and the gears arnt working. Isaid F-it, and went to the LHS and got the 130$ one. Ill turn around and try to fix this one for a back up. |
you could buy the servo gear kit, but if its freaking out, your better off just chucking it.
I just put a post in the driftng forum the other day, with the exact same problem, with the same servo which is about a month and a half old. It wast pushed hard either as it was ran in a TT01 as a steering servo. Ran good for about a month then the same problem pretty much exactly as you described happened to me. I opened mine up and everything still looks new inside, with nothing binding in the gear train. I believe the circuit board has gone on mine but dont know for sure. Havnt decided if I am going to try the warranty or not. Weird that this would happen to both of us at the same time with the same servo.
