the the position of the centre diff QUESTON?
Hey guys.
Well im finishing off my conversion for my truggy and i need to know if it would cause any problems/premeture wear on drive cups/shafts by moving the centre diff a cm or two over to the right so i can fit my battery tray in. Having the drive shafts on an angle now, is that okay? Please help ASAP. <br type="_moz" /> |
RE: the the position of the centre diff QUESTON?
My D8T truggy has a bit of an angle on the driveshafts with the diff offset from the factory, no issues.
shouldn't if the move isn't too far
just be careful that the spur gears clear the chassis when I did my X1 CRT I flipped the diff around, and had to grind the chassis out under a little where I put the spur cause it was hitting the chassis |
| All times are GMT -8. The time now is 12:32 PM. |
