slayer pro
hello all I'm new to the rc world I bought a used slayer 4x4 had to purchase new engine and it won't start any suggestions also what tires come stock previous owner made it dual in rear with real small tires
RE: slayer pro
ORIGINAL: evilchim Hello all, I'm new to the rc world. I bought a used slayer 4x4. I had to purchase new engine and it won't start, any suggestions? Also, what tires come stock? The previous owner made it dual in rear with real small tires. Stock ones are 2.2/3.0 short course wheels with 14mm hexes. |
RE: slayer pro
Well, with a new engine, if it won't fire, it's either a glow plug/igniter issue, or a fuel issue. Pull the plug and stick it in your igniter, make sure it glows bright orange. If it does, then you need to make sure you've got fuel but are not flooding.
To prime for starting, just crack open the slide on the carb (with air filter off so you can see), pull the tube off the exhaust pipe, and blow into it gently until you see a couple drips come out and run down the venturi. If it still won't pop, then you may be flooding. If the plug is dripping with nitro after you've yanked the rip cord a few times (and you know the plug and igniter are good), then you need to back off the idle screw and/or run in the low speed mixture screw. |
RE: slayer pro
Thanks for help plug and igniter are good I believe its flooding plug gets soaked willvtry methods wgen my easy start arrives tired of the pull start
RE: slayer pro
Set tuning needles to default and start over.
RE: slayer pro
Is there some tranny fluid I should by or what do I use to lubricate the tranny
