RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   where do I set throttle on reciever??? (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/11599290-where-do-i-set-throttle-reciever.html)
rc10gtnewuser 05-20-2014 08:24 AM
Is there a good spot to set the throttle on my receiver??? I have It turned down all the way so when the car idles It wont move. Is that good or no?
EXT2Rob 05-20-2014 09:27 AM
Welcome!
Are you talking about the throttle TRIM? Trims are usually "centered" not turned all the way one way or the other. But if the car idles fine, doesn't move when idling, and takes off fine when you give it throttle, you should be just fine.
Big Alice 05-20-2014 01:35 PM
If you set your idle with your transmitter trim, your motor will die when you put on the brakes. set the idle with the idle stop on the carb.
