Rear wheels "toe in"
Why am I seeing this on nearly every 1/10 scale car? I see it on nearly every on road and even my Axial EXO Terra buggy was like that. I straightened them out on the Terra buggy and found no change in performance. I have a new TT01 type that is not like that, the wheels are straight and it runs great.
Why are they toed in? |
makes the car pull in a straight line.
Meaning what exactly? I don't get the theory. I'm sure the car makers have done their research which is why so many are like this. I just don't get it. I always thought a car with all 4 wheels perfectly aligned would track straighter. Is this a feature mostly seen on entry level cars? Because I have seen plenty of cars that don't have this. Many are high dollar.
I didn't write this. stole it from another forum. copy and paste.
Toe is the angle (inwards or outwards) that the tires point when the wheel is straight ahead. Toe-in means the front of the tires point inward, and toe-out means they point outward. Zero toe means the tires are parallel to each other. The biggest effect toe has on the handling of the car is on stability. When a car hits a bump or enters a corner, forces on the tires act to steer the car off to one side, making the car unstable and difficult to control. Toe-in counteracts this, improving stability. Toe-in also causes understeer during initial corner entry. Interestingly, toe on the rear wheels has the same effect on handling as toe on the front. Toe on the rear wheels is useful for tuning the handling of the car as it is exiting corners. Front Toe "IN" Slower steering response More straight-line stability Too much will casuse greater wear at the outboard edges of the tires Front Zero Toe Medium steering response Minimum power loss Minimum tire wear Front Toe "OUT" Quicker steering response Less straight-line stability Too much will cause greater wear at the inboard edges of the tires Less Rear Toe "IN" Less straight-line stability Less traction out of the corner More steering Higher top speed Intermediate Rear Toe "IN" Intermediate straight-line stability Intermediate traction out of the corner Intermediate steering Intermediate top speed More Rear Toe "IN" More straight-line stability More traction out of the corner Less steering Less top speed |
Originally Posted by tqgtragese
(Post 11887378)
I'm sure the car makers have done their research which is why so many are like this.http://lifehealthus.com/9ce14.jpg
Originally Posted by ScarabChris
(Post 11887528)
An exact line from my post. Something tells me this is a spam bot.
Big Alice basically covered it, Wear and tear has a lot to do with it as well
| All times are GMT -8. The time now is 03:57 PM. |
