RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   NEED HELP - Throttle Servo (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/11614870-need-help-throttle-servo.html)
RWTDCT 03-19-2015 04:50 PM
I just replaced my throttle servo on my HPI 5SC with a HiTec HS-5645MG. Once I got it hooked up I noticed it turns opposite of the stock servo. Throttle and brakes work backwards on the radio. I can turn the servo around 180 degrees to get it to work right, but then linkage is way off. Can someone tell me what's up?
I also replace the steering servo it works great.
Maj_Overdrive 03-19-2015 06:14 PM
99% of the radios out there have a channel reverse switch or programming option just for this reason. Reverse the throttle channel, re-center the servo and linkage and you'll be good to go.
DieHarder 03-19-2015 06:15 PM
Flip the throttle reversing switch on your transmitter. This happens sometimes when servos are replaced. It's an easy fix. The switch should be rather small, somewhere possibly on a flat panel section of your transmitter. There is one for the steering too, but since your steering works fine, no need to change that one.
RWTDCT 03-19-2015 06:21 PM
Ok thanks guys...............Now I had installed a RC kill switch which was working. Now that I reversed the servo, when I loose connection it goes to full throttle instead of braking. Any ideas?
RWTDCT 03-19-2015 06:49 PM
Ok I figured it out.........Had to reset the fail safe.
