Venom Speed Meter - How does it work??
Hey folks.. Forget the radar gun.. check out this interesting product:
http://www.nitroreview.com/news/November26-2003.cfm That looks good.. BUT I wanna know how it works! Does it use a #RPM sensor on the wheel ? (yech.. inaccurate) GPS? (yea right! for $50?) Are there any external apparatus involved? ram |
RE: Venom Speed Meter - How does it work??
Hopefully this will answer some of your questions:
http://www.venom-racing.com/inst/VSM...uctions-01.pdf http://www.venom-racing.com/inst/VSM...uctions-02.pdf |
Ineresting. Wont it get inacurate readings when you go from an object with a smaller diameter to one with a larger diameter?
...............you have a point there..................
ORIGINAL: teamsquirreltail Ineresting. Wont it get inacurate readings when you go from an object with a smaller diameter to one with a larger diameter? Maybe when I have extra cash I'll purchase one of these. |
Yeah if you change the size of anything in the drive line, you have to recalibrate it. The size of your tires and your gearing shouldn't change that much, but if it does the readings will no longer be accurate.
Also.. it looks like this will only work with the first speed right?
Ram |
ORIGINAL: BUGGIES_R_US Also.. it looks like this will only work with the first speed right? Ram |
Works just like the bicycle speedometers with the sensor and magnet on the wheel, or a shaft. Can be either very innacurate or fairly accurate depending on how accurately you measure "set up" distance. The "speed meter" simply counts the revolutions of the magnet over the sensor, and uses an equation with the distance you put in to calculate the speed.
how come it will only work with a one speed.
You could use it with a 2 speed, 3 speed, SUV (lol), anything where the wheels contact the ground. If you put the magnetic pickup on one gear of your two speed, it will only give accurate readings of that gear. If you put the sensor on a driveshaft or the wheel (if you can mount the sensor by a wheel, and the pickup on the wheel) it would work for a 2 speed. The directions explain this also.
Peace |
Directions...
Well.. that would be why I asked that question. :) Thanks! I'm not sure I like this system so much. If t it gave me speed info on my RADIO TX.. now THAT would be a nice buy :) ram |
Ah yes, if they could do that, it would be worth gold! That would be crazy!
Looks like it would work great for a bit at least until the first time you taged the rails or someone else... Not to mention How you ever know if it is actually working unless you have a speed gun anyway... Although It is probably pretty consistant and could be very useful to test different setups... Anyone out there actually have one of these things working? |
| All times are GMT -8. The time now is 02:42 AM. |
