RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   a squirt of WD40 In the engine (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/2120156-squirt-wd40-engine.html)
nitroarcher 08-26-2004 08:14 AM
would this be okay to use in the engine to keep it clean of any rust build up, as i cant get hold of any after run oil ?
redheat8 08-26-2004 08:33 AM
RE: a squirt of WD40 In the engine
Actually some manufactures suggest WD40, Traxxas is one of them , water displacement 40 well do just fine, RED
nitroarcher 08-26-2004 08:40 AM
i will spray a bit through the glow plug hole and turn the engine over a couple of times, will it be ok to spray a bit in the carb aswell, Cheers for the reply red, hows it going mate, whats the weather like in that part of the world its miserable here in the UK, keeps raining cant get my car out. [:@]
redheat8 08-26-2004 08:47 AM
The weather is very pleasant here in Arizona, race every weekend, as far as spraying down the carb. goes go ahead sounds like a good idea, and be sure to rest the piston at the bottom of the cylinder , RED
nitroarcher 08-26-2004 08:49 AM
Cheers RED take it easy
redheat8 08-26-2004 08:50 AM
Same to you, RED
Nitro Rustler Racer 08-26-2004 07:30 PM
does wd40 burn when you start the engine or you got to get it out before you start?
biker dude 666 08-26-2004 07:34 PM
yeah good question. I.D. RED is fast evaporating but wd 40 is meant to stay to keep rust from forming.
biker dude 666 08-26-2004 07:35 PM
maybe you could use ballistol oil?[8D]
Evolution02 08-26-2004 07:43 PM
no u dont need to take out the wd-40 because i do it like once every 2 days and it keeps the motor running smooooooooooooooooothhhhhhh
nitroarcher 08-27-2004 12:50 AM
you cant beat a nice smooth sound to your engine, i popped some in the engine and carb last night, might not get out for a couple of days it wont stop raining here [:@]
redheat8 08-27-2004 08:18 AM
Water Displacement 40, is just that is helps to combat against rust and moisture , mind you that the fuels that we use to operate or cars and trucks attract moisture which in hand starts the corrosion or rust ,by using a wd40 or oils it helps to prevent such thing from happening, RED
N-4-Speeed 08-27-2004 04:21 PM
It definitely prevents rust and everything, but my maxx takes FOREVER to start if i have done WD-40 on it the night before. Instead of like a few seconds, it takes over a minute and once it is running you cant give it gas til it burns off the WD-40 or it will stall. Now i use after-run oil and it starts fine.
redheat8 08-27-2004 04:28 PM
Cool are you or were you using alot of wd40 at the time? It really does n't take much, RED
kimberklr 08-28-2004 07:14 AM
i also use wd40 as after run.have been for along time without problems.
some say it ruins glow plugs but i haven't ruined one yet.they also say dont put down your carb as it might attack some of the seals in there.so that leaves putting it into the head which is fine but you must be real careful to clean around your glow plug first.acouple specs of dirt falling in there can be very harmful to your motor.
N-4-Speeed 08-28-2004 11:34 AM
Yeah i probably was over-using it. I sprayed for about 2 seconds into the glow plug hole and it was completely filled [>:].
