RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   HPI Rally Steering... (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/2201176-hpi-rally-steering.html)
aznboi133 09-25-2004 02:05 AM
how do i adjust the wheel angle, chambers or whatever... i have a HPI Rally and when i leave the steering wheel in nutral the servo leaves the wheel in a slight bit of a right turn
dbow 09-25-2004 03:04 AM
RE: HPI Rally Steering...
1 Attachment(s)
Sounds like you are talking about TOE IN and TOE OUT, you may have some excessive TOE on one of your wheels. You change this using the steering linkages. This is depicted on page 10 of the instruction manual for the Rally.
Also note that part A185 the steering joint is a source of slop in the steering design, what I have done on all my cars is replace that with ball cups and a shaft link the steering linkages. Takes all the slop out of the linkage.
Dbow
aznboi133 09-25-2004 04:12 AM
is that change of steering expencive? coulndnt i jsut add more distance to part A187? like split them out more? where do u get the manual? is there a computer version manual? i bought the car used
dbow 09-26-2004 01:47 PM
ORIGINAL: aznboi133
Adding distance to the steering linkage (split them out more) is how you change the toe amount...so yes.
The other thing I was talking about is something seperate from setting the TOE angle. I was speaking of the steering joint A185 in the picture. That joint creats a lot of slop in the linkage and gets worse over time. It may not be a big deal for you but I was just advising of a simple mod. Which would basically be adding to ball studs to the holes where the joint is and then adding 2 threaded ball cups and a shaft. Basically like the steering linkages.
The manual can be found at [link=http://www.hpiracing.com]http://www.hpiracing.com[/link]
Dbow
