RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Help with engine! (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/2318942-help-engine.html)
bypass911 11-05-2004 01:43 AM
Help with engine!
Ok, my engine starts up really well and idles good, but when I throttle just even slightly, the engine shuts off. I played around with the needle going back and forth from rich to lean but still won't help. What is the problem here? Even just a slight throttle the motor shuts off. I thought it was too rich but seems that's not the case.
redheat8 11-05-2004 09:32 AM
RE: Help with engine!
Well if the carb. is set correctly then check the clutch assemble make sure that the bearings arent worn and the shoes arent sticking, RED
Nitro Rustler Racer 11-05-2004 09:46 PM
try adjusting the LSN, wich is located where the little rod from the servo connects to the carb it ould b to rich
bypass911 11-06-2004 02:11 AM
Thanks guys, I'm finally up and running! I had to break in the engine alot. I went throught about 10 tanks of gas to finally be able to drive it.
