project nikko
Well Project General is on hold cause the steering design is confusing and im still not decided on the rear axle..
But i started another. Project NIKKO! it is a 1.10 scale nikko car that came witha HPI body. 20 turn motor stock. I have a Futaba pistol and receiver.. The steering servo is already installed. Ordered a 14turn Quad wind motor and a ASSiciated 14turn+ ESC and a robinson ultra light 17T 48P gear for the motor. Im gonna get a new body for it, new rims, and possibly some neons etc etc. Hopefully they will be here soon. Atleast once project will be done lol |
RE: project nikko
please post pics of the before and after of it! Thanks! [8D][8D]
RE: project nikko
will do. ill take a few befores now, and hopefully get em up within the day. Its picture day cause after all, Snows on the ground and the mammoth wants to prowl!
RE: project nikko
http://img53.exs.cx/img53/3780/nikko11200x900.jpg
thats kinda little before... stock is on the left,, whats going in on the right... Servo is already installed though. http://img53.exs.cx/img53/8071/mam2800x600.jpg thats a project that NEVER ends. he's my big boy! |
RE: project nikko
OK the things came today, ill take pics and put em up sometime. The motor is a 14T Quad wind..... But feels like a 20turn 1 wind... Is this normal?
RE: project nikko
http://img124.exs.cx/img124/482/v3vpic1800x600.jpg
http://img124.exs.cx/img124/3118/r1wpic2800x600.jpg http://img124.exs.cx/img124/1197/v7wpic3800x600.jpg Had to cut some to make the ESC cooling head to fit and had to cut the battery holder a bit cause i wante to use my 3000mah 7 cell hump battery. I am chargin as we speak and I will see how it performs.. IMO the 14T Quad wind seems a little weak. my mind might change with 8.4V |
RE: project nikko
1st test at 730pm outside and dark:(
test went great, upon wot it spins in circles at 3/4 throttle and i punch it i loose traction and spin out so I have to slowly go from 0-100% motor is running cool so far, ESC got hot, i dont remember if that is normal? one prob is that it started smoking.. I pulled the cover off went inside and investigated. TUrns out the 7 cell battery WIRE was burning into the chassis. I am charging my 6 cell as of now and gonna run that and see how it goes.. My guess would be 35mph. If the 6 cell works out. I might cut out the Middle section and replace it with a sheet of alum as part of the chassis and have everything bolt onto there. A cooling plus also it would be.. ESC needs cooling bad to! |
RE: project nikko
project conclusion. ESC failed.... dam pos... lasted 15min on 8.4V and 14T motor.. prob get a duratrax intelli. who knows when though. idont have a job so its hard to say when
RE: project nikko
try putting the esc a bit higher then it is know, maybe it will get more cooling
RE: project nikko
or even better get a computer fan and make it cool the esc cooling head, use a diff battery for the fan
RE: project nikko
well its dead now.. my esc on my stampede when i had him it never failed with a 13T motor on it.... i should just leave the coveroff next time and if i roll i hope the body doesnt get ripped off
RE: project nikko
IM BACK! Duratrax INtellispeed 12T ESC.
I put the 8.4v battery in it and hoped for the best!!! After severly beating on it the temps are as followed Outside temp. 20deg Inside temp 68deg ESC temp 96.8deg Battery temp 142.4 Motor Temp 145.6 What is the max temp a motor and bat can get before damage? http://img111.exs.cx/img111/2668/nikko5800x6004kk.jpg dont do burnouts on a wood table. those are BURN marks. the table started smoking http://img111.exs.cx/img111/8833/nikko4800x6001um.jpg i was ACTUALLY doing a burnout. yes the tire was smoking a bit http://img111.exs.cx/img111/3534/nikko3800x6001zq.jpg There is my esc mounted on a ALum plate i made.. RX is mounted on the rear http://img111.exs.cx/img111/441/nikko2800x6000lq.jpg tire after math, i think i ruined it http://img111.exs.cx/img111/3746/nikko1800x6003ba.jpg |
RE: project nikko
that looks hard i nevr seen anyone change anything on a nikko car before...for me i cant even take the body off...i think its stuck to the engine or something
RE: project nikko
HAHA my nikko had an HPI body on it. I dunno what that was about. I know it looks like ****, I kinda wanna make an all alum chassis but imo thats a hassle. All i know is i want higher top speed and WAY better grip in the rear. I think 1.25" foams will solve that. It would suck if it would blow away my nitro mammoth :(
RE: project nikko
looks like a old tamiya or kyosho ro me....
| All times are GMT -8. The time now is 08:24 PM. |
