LST engine problems
My stock lst will run for about a half of a tank and then bog down and die. When I get it restarted it will run a little then rev to high rpms and die. I broke the motor in according to specs. and now I can't get a full tank ran through without this happening. Any ideas?
RE: LST engine problems
it sounds like it is running lean [:@]
richen it up a little and try it again? what temp are you running at? |
| All times are GMT -8. The time now is 06:02 PM. |
