RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Pullstart repair (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/3606046-pullstart-repair.html)
J_D 12-01-2005 07:34 AM
Pullstart repair
Hey people.
Can anyone link me to any pullstart repair guides.
The string on my pullstart just doesn;t wanna go back into its home. And i wanna read up a bit before i take it apart and have springs flying at me [8D]
Thanks :D
d2cs2mdw 12-01-2005 10:28 AM
RE: Pullstart repair
Get a new one way bearing!
Old_Guy 12-01-2005 11:57 AM
ORIGINAL: GT RaCeR
How would that fix the spring in his pull start ?
teamrayman 12-01-2005 01:35 PM
open it up. if the string is not going back in the spring is broken. if it broken where it attaches to the cover its easy to fix. you just need to bend a bit of the spring and put it back where it broke off.
J_D 12-01-2005 07:26 PM
kool thanks
E-snake 12-03-2005 11:56 AM
you probley pulled the string to far and wore out the spring. you can probley find a new one. When you are pulling the string, it should only be pulled 12-14in away from the pull-start.
Ethan
wave waker 12-03-2005 12:22 PM
1 Attachment(s)
i can imagine how surprising as soon as u open the starter and sunddenly springing out, without any idea at all what's inside.
btw, if u want to, when putting it back try to put a paper gasket between the engine and the pull starter to prevent oil accumulation and prevent slippage. i did custom gasket, u can get from car store.. shown below is a used oil soaked gasket from .15 engine.
cavfighter 12-03-2005 12:41 PM
good idea with the gasket. I just had to replace my pull start mech on my rush at $18 because I pulled it to far on accident. I will try the gasket when I install it
Evader 53 12-03-2005 02:56 PM
The same thing happended with my evader. All I did was give it some yanks and eventually it retracted.
