First Timer... need help
I went out and bought the HPI MT2. First car ever! I read and did what the manual said for break in. Took the car to the park Saturday and ran it. SWEET!! Ran great! Went to run it yesterday and it wouldnt start. Someone told me to put my finger on the muffler hole and crank it a few times then try to start it again. When I did that I noticed fuel and air coming out from the fins under the motor.
I went out today and bought the HPI 18SS. Built it up and I am currently breakin it in. 4th tank and 1/4 throttle in circles around the yard. I started to lean it a bit and notice that while I lean it, it wants to take off in the idle position. Also, I had temp at 222F. Now while leaning it the temps are rising to high. 254F My Q's are...... 1) How do I stop the car from taking off while in idle? 2) How do I keep the temps steady while leaning it? Mind you this is my first car and I dont know all the lingo so if it could be explained in laymans terms I would really appreciate it. I cant afford to go out and buy another engine unless I get divorced first!! :D |
RE: First Timer... need help
Dude I dont know anything about nitro and seen this post all day and feel bad for you. Try posting it somewhere else where someone might reply. Best of luck
When you cover the exhaust with your finger, you are priming the engine for start up. Make sure to look at the fuel line and stop ones the fuel reaches the carb, otherwise you will flood your engine. Basically when you do this you are pressurizing the fuel tank and sending fuel to the motor. (make sure glow plug starter/warmer is not on the motor yet)
fuel and air coming out from the fins under the motor. 1) How do I stop the car from taking off while in idle? Check your clutch shoes, make sure they are not in reverse position where it engages early at lower rpms. When I start my car, I open up the throttle a little with the controler trim, as soon as it starts it will try to take off, I just make sure its blocked with something heavy or my foot (the clutch will slip - make sure this only happens for a second or two) or I lift the rear tires so they just spin until I close the throtle to idle setting. 2) How do I keep the temps steady while leaning it? I had temp at 222F. Now while leaning it the temps are rising to high. 254F What does the manual says in terms of operating temp range for the hpi 18ss? |
| All times are GMT -8. The time now is 06:14 PM. |
