RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Installing Throttle Stop Screw (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/4496079-installing-throttle-stop-screw.html)
joshiestevens 07-13-2006 05:01 AM
H, I am reassembling a Cen NT-16 Rotary Carb and just cant seem to understand how the thottle stop screw works, and keeps the carb open at a certain position when it idles. I have it screwed in, but it makes no sense that when you tighten it the hole opens and lose it the hole closes (or the other way round). All I can see happening is the screw fitting into the groove...
Hope someone can help
Josh
slodsm 07-13-2006 09:22 AM
RE: Installing Throttle Stop Screw
Really not understanding your question. The screw goes into the carb and only allows the throttle to close so far. It's a mechanical stop so the further you screw it in, the soon it will stop the carb from closing thus the larger opening at idle. It's pretty simple.
joshiestevens 07-13-2006 07:09 PM
all sorted thanks
ASSOCIATED_DRIVER 07-13-2006 09:41 PM
I believe it is also called an Idle adjustment screw.
