RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   piston sleeve (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/5408756-piston-sleeve.html)
heli 02-12-2007 04:39 PM
piston sleeve
HOW DO I REMOVE IT? Will a sleeve from a .15 fit in a 2.5? THANK YOU
125cchyperman 02-12-2007 07:32 PM
RE: piston sleeve
Take the head off the engine and take the exhaust off the engine. I mean the header part, then move the piston to BDC and take a zip tie and stick it through the exhaust port into the cylinder. Then move the piston up and keep on going up till the sleeve has been pushed up a little. Then move the piston back down and take the zip tie out. Then grab a hold of the sleeve and remove it.
Yes a .15 sleeve will fit in the 2.5 as there the same size engine. A .15=2.5. The .15 is in Cubic Inches and the 2.5 is in CC's. But make sure there from the same type of engine though. Another words dont take a cvr .15 sleeve and stick it in a TRX engine.
DaveG55 02-12-2007 08:26 PM
RE: piston sleeve
If you're asking if a sleeve from a Pro.15 will fit into a 2.5r then I don't think the'll fit. They may both be .15 size engines but bore, stroke and porting will all be different...I think. I could be wrong but I do believe that I read somewhere that they are not interchangable.
