problems
ok i just boutght nitro buggy and its being a ***** i cant get it to like idol i half 2 pick it up 2 start it and when i press the brakes it turnes off or if i slow it down 2 much it will just shut off pleases this is pissing me off thanks
RE: problems
clutch is seized.
RE: problems
Yep, clutch springs probably.
RE: problems
none of the above. u have no idea what ur doin
RE: problems
u think thas what it is can there b n e thing else
RE: problems
Not really, if the wheels are turning from the moment you run it, and it stalls when you stop the wheels, then the problem is definitely in the clutch.
RE: problems
thanks but like what would i half 2 buy the whole clutch or like like the clutch bell thing kkinda new 2 this stuff
RE: problems
RE: problems
Shouldn't he check his idle first? If breaking closes the carb completely, then it will shutdown. Pull the airfilter and look down the carb. When breaking there should still be a small amount of space open.
Just my $0.02. |
RE: problems
thanks i found out it was the clutch spring i think because i broke pullstart and now i am just waiting 4 the estarter 2 come so well c how it goes
| All times are GMT -8. The time now is 12:54 AM. |
