Lean Engine
if the top of your piston in your engine is black does that mean u ran the engine to lean?
RE: Lean Engine
i thoguth deposits mean it was running too rich
RE: Lean Engine
No a big hole in the top of your piston means its running lean:D
A thick layer of crud is due to running rich or leaving fuel in your engine [&o] |
RE: Lean Engine
you should run rich but let your engine run dry,until theres no fuel at all and the car stops becuse of it. it keeps your engine lubed but it also gets rid of unwanted left over gunk in there.:D
RE: Lean Engine
thanks for the help
RE: Lean Engine
ORIGINAL: irockdude you should run rich but let your engine run dry,until theres no fuel at all and the car stops becuse of it. it keeps your engine lubed but it also gets rid of unwanted left over gunk in there.:D |
| All times are GMT -8. The time now is 11:48 AM. |
