RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   wuts wrong wit this motor!?!?!?!?? (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/5935581-wuts-wrong-wit-motor.html)
ricer 06-02-2007 05:54 PM
i finally got my warhead started and when i got it started all it does is revv really really high and i i cant stop it at all. it doesnt move but the gears are spinning fast but the truck isnt going anywhere..... i cant accelerate or brake or anything when it is on... what is wrong with it?
nitro _ burner 06-02-2007 08:28 PM
RE: wuts wrong wit this motor!?!?!?!??
ok what you have to do is pull your air filter off and look down the carb throat, you should see a little wall thing that is supposed to slide open and shut when you apply/lett off the throttle. what you need to do is screw the idle screw untill the little wall starts closing (wou want about 1-2mm of space) then start her up and see how it runs then get back to us.
Hop this helps.
ricer 06-02-2007 09:09 PM
yea is the idle screw the low speed needle by any chance??? im sorry i dont have very much knowledgement of this stuff......
kingtuts 06-02-2007 10:27 PM
the real question should be whats wrong with the way u typ. i know whats wrong with it. its ****in stupid thats whats wrong with it
dcross405 06-02-2007 10:52 PM
is it a new truck?
Nick2618 06-03-2007 12:08 AM
The idle stop screw is some where on the carb. There is 3 adjustable screws on your crab. The HSN, LSN, and idle screw. Find the idle screw and screw it in until it is just about 2-3 mm away. Then start the truck if it dose not start unscrew the idle a little bit and try again. once you get the truck running you can fine tune the idle screw with it on and listen to the engine.
sfar785 06-03-2007 12:41 AM
ORIGINAL: kingtuts
You sir, are a moron....quit posting in the forums if you don't have anything useful to say.
nitro _ burner 06-03-2007 08:41 AM
then once your idle is set you can start fine tuning:D
