Steering trim
Hi. What does one do if the steering trim dial is maxed out in one direction and the trim is out.... How do you reset this? I have the electric Traxxas Rustler. Thank you. :D
RE: Steering trim
Put the steering trim back to the middle, then remove the servo saver (or servo horn) from the servo. Next turn on the radio and car so that the servo will center, then turn everything off. Finally replace the servo saver with the wheels facing forward.
RE: Steering trim
take the horn off of the servo and center the trim on your remote, then put the horn back on so that it's 90 degrees on the servo. your tires should be straight
RE: Steering trim
Center the trim on your radio, take of your servo horn, turn on the ESC and radio so the servo centers, replace the servo saver so it is facing straight up, adjust the steering linkages until your tires face forward.
| All times are GMT -8. The time now is 03:27 AM. |
