Pull start problems
I hat e the pull start on the Super Nitro, always having problems. I am on my third one. I there any modification you can do to eliminate the pull start?
RE: Pull start problems
ORIGINAL: JReaney I hat e the pull start on the Super Nitro, always having problems. I am on my third one. I there any modification you can do to eliminate the pull start? Or theres the good old starter box,other than them I don't know what to tell you to use. Are you over pulling the pull starts more than about 12-15 inches? that could be your pullstart problems or you might of put the oneway bearing in the wrong way when you where fitting them,if you said you are on your 3rd! Hope that helps[:o] |
Tiger drive may fit then all you need is a cordless drill.
| All times are GMT -8. The time now is 04:11 AM. |
