RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Adding An Extra Fuel Tank ? (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/6371936-adding-extra-fuel-tank.html)
Crash_Course 09-15-2007 03:57 PM
Hey, again guys.
Well I just got back from bashing around, when me and my dad had an idea of adding an extra fuel tank to the other side of the buggy (1/8th scale).
There is quite a bit of room on the other side for an 80cc to possible another 125cc tank, which would give me hopefully about 20 to 25 minutes of run time.
I have some questions though:
1.) Is there such a thing as "connectors" to connect two fuel and pressure lines back to one? Like It tried to "draw" below :)
-------\ \_______
............._______ Ignore the dots.
2.) Would their still be enough pressure to properly pressurize two tanks ?
3.) Would it harm the engine running it for twice as long without stopping it ?
And, has anyone else tried this?
Thanks Guys:D
Nick2618 09-15-2007 04:10 PM
RE: Adding An Extra Fuel Tank ?
not sure the layout of your buggy but maybe you could fit a oversized boat or plane tank on it?
Crash_Course 09-15-2007 04:36 PM
Here is a picture of where I would add the tank, the area is actually taller then it looks. It is as tall as the servo is.
http://img406.imageshack.us/img406/5672/rccar003oz7.jpg
drevil 09-15-2007 04:38 PM
ORIGINAL: Crash_Course
-------\ \_______
1. What you're looking for is a T connector. There are numerous companies that sell that, but I'm not certain of the fuel line size so you'll have to look that up.
http://www2.towerhobbies.com/cgi-bin...93p?&C=QCG&P=7
2. I think it would run fine, but since I haven't done it I can't say for sure.
3. Nope. It wouldn't be any different than filling the tank up over and over again. As long as it's tuned correctly you shouldn't have a problem.\
Personally I'd go with one larger tank. It shouldn't be all that hard to install and would be much less complicated.
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=QCA
Crash_Course 09-15-2007 04:53 PM
OK, thanks:D
I will look into those sites and see what I can find.:D
ST-R 09-16-2007 01:55 AM
this is mgt with two tanks
http://www.rc10.com/racerhub/racersp....racerspot.htm
it looks like hes add the exhaust to 1 tank and then the fuel line to the other thank by the presure line so really only 1 tank is pressurised hope this helps
cooptroop123 09-16-2007 05:35 PM
yea if you run the tanks in series that would be the best way i think but if you wanted to join the fuel lines and split the back pressure that would be fine, because each of the tanks would need to supply half the fuel of one so the only need half the back pressure
jatoracing33 09-16-2007 06:42 PM
1 Attachment(s)
how bout just make a chain...have the pressure line go to the new tank, then the new tank have a line to the original tank, and then the original tank go to the engine...if i made it sound confusing then just look at the pic cuz i couldnt find a good way to describe it
So Cal 09-16-2007 07:01 PM
What jatoracing is talking about works, i have done it.
ST-R 09-17-2007 01:21 AM
yeah thats how the mgt is setup
Crash_Course 09-17-2007 10:00 PM
Actually I like that idea better, defiantly looks a lot easier. I will look into it [sm=thumbs_up.gif]
:DThanks Y'all
Probedude 09-19-2007 12:44 AM
definitely go sequential - that way you'll drain both tanks completely. If tee'd together, one will drain first and then just push air through - the other tank will then stop feeding fuel.
BuzzBomber 09-19-2007 08:52 AM
As noted above, plumbing the tanks in a series configuration is the way to go. Usually this configuration is referred to as a "header" tank. Heli flyers use it to ensure smooth fuel flow during wild maneuvers. If you have any more questions about setting it up, the heli forums might be the place to ask.
