RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Engine replacement for TS4N (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/650189-engine-replacement-ts4n.html)
Scooby_Dont 03-26-2003 02:04 PM
I am considering buying a new engine for my TS4N. I need to know which type of shaft the thunder tiger uses (SG, pilot, or threaded). I would prefer an engine that will fit right in without buying a new flywheel \ clutch etc. BTW I have the two speed transmission with the interchangeable gears and would like to continue using this with the new engine. Thanks.
dg2b 03-26-2003 06:14 PM
According to thunder tiger, the TS4N ARTR version comes with the pro 15 engine. The engine pics "seems" to be SG crank.
You should check you engine to make sure that is the right crank. There are a lot of SG crank engines out there. The flywheel/clutch/etc should be universal to SG crank engines. You might need to buy a motor mount.
petrolpixie 03-26-2003 07:19 PM
i have a ts4n pro with the new thunder tiger evo 12 in it. it has a claimed 1.1 hp. you should be able to use all your existing parts on this engine. regards, adrian
