RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Grease Problems Please Help! (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/6657486-grease-problems-please-help.html)
Victorious Secret 11-22-2007 01:25 AM
Hello All,
In the middle of building the TT01 Chassis, I ran out of the Tamiya Grease that came with the kit. What can I substitute the grease with? Can I use Damper oil, WD-40, or Vaseline? If I have to run out and buy some grease, what type of grease can I buy that is available at Walmart? It's 2:24 am right now.
Thank you for your help! I would like to finish building by morning!
VS
sheograth 11-22-2007 02:53 AM
RE: Grease Problems Please Help!
jeez you went through it fast, I always have some left over after my builds. Of the remedies you mentioned, damper oil will work (provided its silicone based).
boltech 11-22-2007 09:21 AM
Get a big tube of Super Lube from home depot. works very well
Don't forget to get the alloy drive shaft and ball bearing kit!!! they can be had for cheap and fast from hong kong.
http://www.super-lube.com/
hkenvy91 11-22-2007 10:55 AM
white lithium grease from auto parts store
Victorious Secret 11-22-2007 04:09 PM
Thank guys!
It was at middle of the night while I build this and I really wanted to finish it! So I took Sheograph's idea and use dimper oils to finish the build. I hope there are no reprocussion for using damper oil instead of grease.
Yes I added the alu shaft, ball bearing kit, and drift tires... I think I will add the shock next and an 19T motor with heatsink. I'm also in the middle of converting my TA02 chassis into graphite and making it to a drift machine as well. Here's the picture of my newly built chassis.
http://i113.photobucket.com/albums/n...rs/Chassis.jpg
Any comments and suggestion are most welcome.
VS
