rounded nut
Hi
I have managed to round the nut that keeps the engine to the chassis, it is a allen screw. How do I undo it ? |
RE: rounded nut
If you use a small drill bit with your drill you may be able drill the head of the screw until it breaks off, then remove the engine and carfully use pliers to carefully remove the rest of the screw. I have never done it on my rc cars but have on many other aplications, it should work if you're careful.
RE: rounded nut
You could:
-Cut a slot into the head of the screw and use a flathead screwdriver to remove it -Threadlock an allen key into the screwhead, let dry, and unscrew -Use vise grip pliers to grab the head and turn |
RE: rounded nut
use a screw extracter
RE: rounded nut
You could: -Cut a slot into the head of the screw and use a flathead screwdriver to remove it -Threadlock an allen key into the screwhead, let dry, and unscrew -Use vise grip pliers to grab the head and turn |
RE: rounded nut
i have done that several times with the cheap screws on my towerhobbies st-15. Just take a smaller bit then the screw and drill it. After you get into you can pull the engine off the chassis and take pilers and unscrew the screw.
cutting a slot in teh screw requires a dremel usually and i dont have one but that sounds like the best idea... |
RE: rounded nut
The slot idea works well, and you can also try tapping the end of the screwdriver before turning. That helps sometimes to shock it into breaking loose a bit. Also, some light oil or WD40 soaked into the thread can help it.
RE: rounded nut
last time i did it i drilled the head of the screw off as said above and used vise grips to get the rest out. works pretty good.
| All times are GMT -8. The time now is 09:28 PM. |
