RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   spin problem (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/675050-spin-problem.html)
keeyen 04-06-2003 01:21 PM
spin problem
Hi Pro out there,
I'm driving a Thunder Tiger TS4n pro with TT EVO engine. the car was ok at high speed conner. The only problem was when I was going out of those low speed conner, It need very smooth acceleration or it will spin out. I notice this will happen when there is some steering input and I pull the trigger a little too fast. Any suggestion to solve it?
Alan Pang
Malaysia
PAINT CHIP 04-06-2003 02:46 PM
spin problem
tighten up the front pull loosen the rear ie:grease thicker front thinner rear.or the rear diff may be locking not allowing it to act.
dg2b 04-07-2003 03:29 PM
spin problem
Sounds like an oversteer issue.
Do you have a setup equipment (integy, hudy, rpm, etc)? I would look at the droop, ride height, and camber.
If you dont have a setup equipment, try putting heavier shock oil in the front and lighter in the back. Don't forget experimenting with different pistons.
You can also try heavier springs up front, softer in back. The car will turn wider but should have be easier to drive and high speed steering should feel much nicer. Try a two gap ratings between the springs.
