Oil/Spring Tech (Your Setups For Basing)
Hey guys,
I am rebuilding my shocks on my Evader and am wondering how to set up my suspension for high ramp jumps, and slightly bumpy terrain, no racing. I am thinking of using firm springs with 30 weight oil. What are your setups for bashing? Please share...[8D] Shredder111[>:] |
RE: Oil/Spring Tech (Your Setups For Basing)
Anyone?[:o]?
As a starting point I will always use 22.5 oil in the front, 25 in the rear and for 2WD, about -2 or -3 degrees camber in the front (doesn't hurt for 2WD), 0 degrees camber in the back, or close to it, 1-2 degrees toe-in on the front and 0 degrees toe in the rear, 2 degrees anti-squat, sometimes I make the front shocks a little more horizontal if I am still not getting enough steering, as for tightness maybe 2 steps above stock in the front and 1 step above stock on the rear, etc.
http://users.pandora.be/elvo/15/1.html You can't really think of just one setup alone, you need to think of the truck as a whole. You drive it a bit, try to find faults with how it handles, and then try to correct those faults, its an iterative process. |
I know, I'm just wondering about generally solid setups for bashing. Thanks though...
stiff springs/oil for big jumps.;) Common sense really.[8D]
ORIGINAL: Access As a starting point I will always use 22.5 oil in the front, 25 in the rear and for 2WD, about -2 or -3 degrees camber in the front (doesn't hurt for 2WD), 0 degrees camber in the back, or close to it, 1-2 degrees toe-in on the front and 0 degrees toe in the rear, 2 degrees anti-squat, sometimes I make the front shocks a little more horizontal if I am still not getting enough steering, as for tightness maybe 2 steps above stock in the front and 1 step above stock on the rear, etc. http://users.pandora.be/elvo/15/1.html You can't really think of just one setup alone, you need to think of the truck as a whole. You drive it a bit, try to find faults with how it handles, and then try to correct those faults, its an iterative process. Uh what that Brad guy said is pretty much it. |
| All times are GMT -8. The time now is 05:02 AM. |
