have the wrong engine help
i jus got a factory team rc10gt and had a .12 cvr laying around i went to put it in and its a regular style crankshaft, how do i make it short can i cut it or but a ne crankshaft, i have no money for a new engine.
You have to use the cut off nut that came with you FT kit. It's in the bag with the clutch parts. Put that on and cut the shaft of flush. There are pictures in the back of the manual that describe and show in detail how to do it. It's very easy and you won't have to buy a new anything. I recommend using a dremel tool for the cut. Could also use a hack saw if necessary.
| All times are GMT -8. The time now is 05:49 AM. |
