Help!
I can't get the rubbery connector thing onto the end of the pipe. I've already broken one rubbery connector thing trying, and this is my last one :(
I can't believe I'm being outfoxed by a rubbery connector thing, anyone have any tips as to how to get it on there? http://i4.photobucket.com/albums/y13...2/DSCF1132.jpg |
RE: Help!
if you have a butaine tourch heat up the pipe the push the rubber thing into the pipe
but if you dont have a tourch put the rubber thing in the freezethen stick it in |
RE: Help!
LOL @ rubbery thingy. I think it's called a coupler. looks pretty small for the pipe. What kind of pipe is that? Maybe send the company an email and ask them for ideas. Or go to the hardware store in the plumbing dept and see if there is a possible rig job you can make work
RE: Help!
ORIGINAL: DriftingDragon if you have a butaine tourch heat up the pipe the push the rubber thing into the pipe but if you dont have a tourch put the rubber thing in the freezethen stick it in funny the pipe goes in the coupler not the coupler in the pipe sheograth try putting the coupler in boiling water to heat it - don't use a torch - and some lube on the pipe you could also round the sharp edges in a bit but w/o altering the groove for the zip-tie are you sure that you have the right size coupler? |
RE: Help!
Gah I got it on.
Stretched it with pliers and forced it. It's the same size as the one that came with the pipe :/ (which I tore). Anyway, I can calm down now it seems. [&:] |
RE: Help!
In the future, you can also try some dish soap. That seems to get things slippery enough for even the most difficult of rubbery thingys [&:]
Your word choice is impeccable [sm=thumbs_up.gif] |
RE: Help!
ORIGINAL: sheograth Gah I got it on. Stretched it with pliers and forced it. It's the same size as the one that came with the pipe :/ (which I tore). Anyway, I can calm down now it seems. [&:] Like spraying electric motor spray in a brand new tekin esc, luckly I only had to pay 100 bucks for a new r1 pro, it's a 225 dollar esc though...not cheap :/ |
RE: Help!
RE: Help!
Nice work, you master thingy installer :D
RE: Help!
I wonder how long it will tale for it to rip. [:o]
| All times are GMT -8. The time now is 02:18 AM. |
