RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Servo problems (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/7477751-servo-problems.html)
brendonv 05-09-2008 10:54 PM
Servo problems
Hey i got the Team Losi XXX-S and when i turn left it goes all the way left like it should then wen i let the wheel go it centers again but when i turn right it goes right but when i let the wheel go on the transmitter the car doesn't center, i cant really tell when im driving that its not straight but i want to fix it up. It all happened when i decided to play around with the toe in/out settings. Now the servo doesn't center properly, i think i no how to fix it, do i need to try center the servo because the servo center point isn't straight up its a little off to the side when i got the car and i think i put it out a bit when moving all the servo arms out and in. The only reason i dont get why it would be that is, wouldn't it be out when i turn left and right and not just right if it was that?
Please help.
Im going to take my car down to the track for the first time in a week so i need to fix it soon.
From brendon.v
brendonv 05-10-2008 10:17 PM
RE: Servo problems
Please Help!!!!
nitrofan12 05-10-2008 10:37 PM
RE: Servo problems
first try centering the servo as you have stated then see if your servo reverse switch for steering on your transmitter is wrong.if that does not work check your servo saver and if that does not seem affected then it's your servo
brendonv 05-11-2008 12:42 AM
RE: Servo problems
servo reverse switch? How do i check my servo saver?
brendonv 05-11-2008 03:21 AM
RE: Servo problems
i sorta fixed it, i put the steering to 0 on the transmitter, took the steering arms off, adjusted em then put em back on. There not 100% i mean it still goes a bit to the left and right wen going but ill get it 100% later on.
