RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Engine break-in stand? (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/755055-engine-break-stand.html)
ridethelightnin 05-08-2003 03:39 AM
I have an extremely tight engine (Rody C5) that I am going to be breaking in and I was wondering what some of you guys use to break-in your engines? I have read about a Hudy engine break-in stand but couldn't find much info about it.
Any suggestions regarding a engine stand would be helpful. I may just use a big vice with the engine mounted on some blocks of wood.
Anyways, any help/suggestions would be appreciated.
:D
speedracer0_7 05-08-2003 03:49 AM
most people i've seen just mount the engine in the car and use a starter box, but u can break in the motor using a airplane break in stand but u will need a airplane starter, prop,and spinner.
packfan88 05-08-2003 03:51 AM
what did you pay for that motor with shipping?
whats hp and rpm claims?
what ya puttin it in?
speedracer0_7 05-08-2003 03:58 AM
take the glowplug out and bump the motor on the starter box and try 2 loosen up the motor, then when u put the plug back in don't tighten it all the way leave it loose and try 2 start the car, if the motor gets stuck on top dead center use a srewdriver or something 2 pry between the flywheel and chassis
ridethelightnin 05-08-2003 04:19 AM
I paid something like 535 or something for the engine but it came with a larger cooling head. If you are interested in one go to ebay and check out a store named PDL. The guy Mike, I beleive is his name, if very helpful and when you buy an engine from him he takes it very seriously, almost like you are adopting a kid, but nonetheless very informative/helpful. He also had by far the best prices!!
Rody claims close to 3HP at, I think, approx 44K RPMs. check out RB concepts for more info.
I am putting the engine in a Hyper 7 pro.
I do have a really good starter box but the engine is so friggin' tight, with the plug out too, that I don't want to chew up the rubber wheel.
Besides, the "big boys" use engine stands or so that's what they say! :D
