RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Servo Problem (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/7773805-servo-problem.html)
Tilux 07-26-2008 07:26 AM
Servo Problem
I was making my RB-1 Rolling when my gasket broke, (repaired) but my problem got bigger. My servo is all screwed up. When i put gas, its good, when i applie brake, good but when i repeat the move it begin to screw up. When i make it turn right and left, Its going crazy, its going on off and and the direction is going every side and the gas goes to max and block there.
WTH Happened to it?.. [&o][&o][&o]
Help Will be greatly appreciated.
ehroof 07-26-2008 10:00 AM
RE: Servo Problem
did any water or moisture get in the reciever? a
lso make sure all the plugs and the crystals are in tightly.
Tilux 07-26-2008 03:49 PM
RE: Servo Problem
Well, i remember the first time i made it run and it ran into a small hole with water in it, but ran well after. There was that day too when i went to the baseball field, it rained the other day and sand got everywhere. I guess there are still some left in it somewhere. But I know it got wet.
Tilux 07-26-2008 03:54 PM
RE: Servo Problem
And now im in my garage ATM and the electric is not working now. we needed to solder it together, it worked for a moment and now electric is out!!!!
Im getting pretty upset here. [:@]
ehroof 07-26-2008 04:15 PM
RE: Servo Problem
most likely something happened to the reciever when it got wet.
Do you mean the electric went out so you cant solder?
Tilux 07-26-2008 04:19 PM
RE: Servo Problem
I mean the electricity in the buggy, Now I inserted new battery and the battery case and the battery are about 50-60 Celsius. That about 120 farenheit.
ehroof 07-26-2008 04:21 PM
RE: Servo Problem
like i said earlier, you most likely fried the reciever when you ran thru the water, even if it didnt damage it right away, it could have taken a little time to get into something.
you need to put the reciever in a "balloon" to keep it water proof or you really shouldnt run in any water.
Redharris 07-27-2008 12:28 PM
RE: Servo Problem
Tilux.......
If the Battery is getting Hot, then you have a Short circuit somewhere....
I agree with Eddie. You probably have a Damaged receiver.....
Moisture, of Any kind, is BAD for electronics....
Water will not always kill electronics Right Away.
Sometimes, the component will last for awhile before it fails completely.
You are Lucky. If the Throttle channel had filed, you might have had a Run Away.....
Tilux 08-01-2008 05:37 PM
RE: Servo Problem
Well. I guess i short-circuted somewhere and the receiver bad. It's an |R-10|27.195MHz|AM Frequency| Can I find it at my local hobby store? (not an himoto dealer)
I forgot to mention that before the battery came hot. When i plugged only 1 servo, it worked perfectly. The problem only kick in when the 2 were plugged. Now i cant do that now. Battery getting hot. Dont wanna make em' blow up. :eek:
Redharris 08-01-2008 08:52 PM
RE: Servo Problem
Tilux.....
You may have a shorted servo, which MAY have fried your reciever.
You should not plug in a Suspect servo to your new receiver, (which you should be able to buy at your LHS).
MAYBE you can talk your LHS into testing your servo for you.....
