RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Starting problem (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/777926-starting-problem.html)
skirecs 05-16-2003 05:56 PM
Starting problem
I got a brand new HPI 15FE engine and it wont start. When i turn the flywheel by hand, i hear a slite hiss, and i lose a bit of pressure, as i turn the flywheel slowly, i lose compression until nearly nothig, how can i fix this or do i need a new engine.
But its brand new?
Unstable 05-16-2003 06:36 PM
Starting problem
Moved thread to here.
shoehead 05-16-2003 06:52 PM
Starting problem
Where was it?
skirecs 05-16-2003 09:04 PM
Starting problem
thanks
*Crash*Johnson* 05-17-2003 12:54 AM
Starting problem
I think it was in the general forum.
mikesnitrorush 05-17-2003 01:39 PM
Starting problem
the hiss you hear sounds like it is on the compression stroke but i could be wrong, have the carb set right? i believe the factory setting for breakin for the .15fe is 3 turns counterclockwise.
my .15fe in my rush is very dependable and starts on the first pull every time.
skirecs 05-17-2003 02:20 PM
Starting problem
its defintitly compressing, and if i hold it in the middle of compression, the pressure lessens, and that is defintly leaking i think
