nitro rustler help
if u gas on it real slow it goes str8 but if u hammer it u can't keep it from going round and round the wheel bearings roll smooth and str trim is adj good could it be that rear tires r 2 worn or???????? please help
thank u |
nitro rustler help
It could be your rear diff needs re-built.You might be getting more power to one of the rear wheels witch will make it vere off in that direction or maybe your wheel nuts are to tight in the rear and making it do the same thing.
nitro rustler help
Check the bearings in the differential, and the condition of the CV shafts
nitro rustler help
I've had a similiar problem. Before you jump into the diff. Check to make sure your rear shock tower is complete and sturdy. I had a hair line crack in mine and casued my Ruslter 2.5 to do the same thing. Also think about some sturdier shock oil for the rear, make sure the shocks are topped off as well. If that fails you jump into the diff.
| All times are GMT -8. The time now is 11:03 PM. |
