RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Pullstart Woes (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/7903638-pullstart-woes.html)
bonkas 08-30-2008 10:07 PM
Pullstart Woes
After tuning my car for a bit I notice one of the pullstart screws has fallen out and one seems to be loose but I can not tighten as the screw is kinda stripped.
It looks like load of oil is leaking from the pullstart and I assume it's because the pullstart is not sealed as the scres have come loose.
Should I worry about this or just leave it until it falls off and have a excuse for a new pullstart as the cord is starting to get frayed.
ehroof 08-30-2008 11:03 PM
RE: Pullstart Woes
ORIGINAL: bonkas
I dont remember what car you have but you shouldnt have oil in your pullstart, if its a .21 or .28 and a rear exhaust you may have an exhaust gasket leak, if its a .16 or .18 and a side exhaust, your backplate may be loose or leaking, check the screws. I would replace that missing screw before you loose the pullstart, your lhs should have one for you.
bonkas 08-31-2008 12:08 AM
RE: Pullstart Woes
So the backplate is bolted to the rear of the engine and the pullstart is ontop of it?
So I will have to remove the pullstart to access the backplate?
It is a Himto Viper.
If that is the case I will need to take out the whole engine or remove the whole rear of the car to get to the screws... damn.
Redharris 08-31-2008 01:18 AM
RE: Pullstart Woes
Bonkas ....
Take the Engine Out.....Much Easier!
