fail safe
I just bought the megap-3 and I had a problem with the brakes but I fixed that. My question is where do you guys put a fail safe since there looks like there is no room in the batt. or receiver boxes?
RE: fail safe
I put mine on top of the receiver box
DOUG ORIGINAL: madmax93 I just bought the megap-3 and I had a problem with the brakes but I fixed that. My question is where do you guys put a fail safe since there looks like there is no room in the batt. or receiver boxes? |
RE: fail safe
ORIGINAL: madmax93 I just bought the megap-3 and I had a problem with the brakes but I fixed that. My question is where do you guys put a fail safe since there looks like there is no room in the batt. or receiver boxes? Also, the RTR radio and RX is unfortunately massive. Whenever you can save up enough money, a mid-grade radio will have a much smaller RX in most cases, and better yet, those radio gears have failsafe built in! |
RE: fail safe
If you have to put it outside the bat box just be sure to tie strap it to something
RE: fail safe
ORIGINAL: SAVAGEJIM ORIGINAL: madmax93 I just bought the megap-3 and I had a problem with the brakes but I fixed that. My question is where do you guys put a fail safe since there looks like there is no room in the batt. or receiver boxes? Also, the RTR radio and RX is unfortunately massive. Whenever you can save up enough money, a mid-grade radio will have a much smaller RX in most cases, and better yet, those radio gears have failsafe built in! I dont know about the "unfortunately massive", i have himoto reciever in my hand now and its 1/2 the size of a few different futaba's. I dont know of any RTR that has a micro reciever unless its a losi mini or micro t, check out the traxxas or cen rtr recievers. |
RE: fail safe
What is the cheapest fail safe transmiter/receiver set up I could buy?
RE: fail safe
we sell one, its pretty small and not that heavy on the wallet. i run this on a few of my rc's and have no problems.
http://server.sohouniverse.net/~himo...hp?id=978&=SID ***edit*** sorry i didnt notice the transmitter reciever part, lol Spektrum dx2, you get 2.4ghz technology and a build in failsafe for around $169 or less. |
RE: fail safe
I think its actually a good idea to mount your Failsafe where you can Easily reset it.
Too many folks set it Once , stuff it into the radio box, and Forget all about it..... Its Good Practice to actually Reset the Failsafe from time to time. (Its a lot Less hassle than having a Runaway!) |
RE: fail safe
ORIGINAL: Redharris I think its actually a good idea to mount your Failsafe where you can Easily reset it. Too many folks set it Once , stuff it into the radio box, and Forget all about it..... Its Good Practice to actually Reset the Failsafe from time to time. (Its a lot Less hassle than having a Runaway!) |
RE: fail safe
ORIGINAL: HimotoRacingUSA we sell one, its pretty small and not that heavy on the wallet. i run this on a few of my rc's and have no problems. http://server.sohouniverse.net/~himo...hp?id=978&=SID ***edit*** sorry i didnt notice the transmitter reciever part, lol Spektrum dx2, you get 2.4ghz technology and a build in failsafe for around $169 or less. Another thing I forgot to mention: To help save space in the batt box, getting rid of the 4x AA cell pack and going with a NiMH RX batt pack is a big step too. These are smaller, the 5-cell arrangement allows you to slip some of the wiring into the the left and right corners where there are only 2 cells, and most of all, 6V ! The 4cell batt pack can only give you 6V if you go with non-rechargable AA batts. AA rechachables suck because they are only 1.2V per batt :( |
RE: fail safe
4 aa alkaline is the same voltage as 5cell nimh packs, 6v but you can get much more mah(power) out of a rechargable then the alkaline so the rechargable is defintely the way to go.
RE: fail safe
That DX is a little to much for my budget. I was thinking of this radio, it comes with servos.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=270274444598 I will also get a seperate fail safe. |
RE: fail safe
thats a good radio but there is no failsafe built into it.
RE: fail safe
Yes, I will get a seperate fail safe for it.
RE: fail safe
i run that on a couple of my cars and i am happy with it and thats a good price for it too.
| All times are GMT -8. The time now is 06:57 AM. |
